+ Reply to Thread
Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
Thread: steel vs stainless headers (aka - MSDS vs RaceBits) :)
  1. #11
    Join Date
    Oct 2010
    Norwich, CT
    Posts
    267
    Default
    Quote Originally Posted by Harrry View Post
    I have news for you...your accountability based on your years of personally experience fails to back your theory on if the steel headers is similar to the SS offered esp on our cars. Living in Michigan. i regret not getting the weapon r's when i had the chance. Biggest regret! My msds y-pipe rusted like no tomorrow...and my special ordered hot temp coating that msds shipped out to a jet hot coating company flaked off and the headers started rusting in 2 years. Now the rust has spread...and the welds are full of rust. Considering i put literally 3k miles a year on my car. It hasn't seen much of the abuse many others on here have given the msds headers. Imho...it was my biggest mistake.
    On the side of looks! I can def see my headers from the top of my car. And when i showed off my SS tru duals...others always snooped under my car to see the whole exhaust. After all the hard exhaust bending and welding went to crap when you saw the front end of the exhaust. So yes it's crucial esp when your car is meant for more then just a daily driver.
    Thats unfortunate that your coating failed. Your experience is not necessarily a common story though. If you didnt already, you should consider pursuing warranty replacement, as that coating should only fail if it wasnt properly applied in the first place (unless it took some damage somehow such as bottoming out while driving or getting dropped before installation). Either way, its no reason to get snotty. Just state your position so the OP can get the input he's looking for. You did point out something I didnt really address though, that the Y-pipe most definitely gets wet, and even though the stock one is just steel, any opportunity to use a better product should not be passed up.
    Your car is uglier than I am! uh...that didnt come out right.
  2. #12
    Join Date
    Dec 2001
    Gales Ferry, CT
    Posts
    24,502
    Blog Entries
    93
    Default
    Quote Originally Posted by CSVT#49 View Post
    Not true. It all depends on the type of stainless steel not the 'cheapness' of it. 400 series SS will eventually stain/corrode sometimes in just a few months. 300 series SS will last quite a while but can eventually corrode ( but not rust). Most common in this series is T-304, this is what the WeaponR headers and I believe the new Racebits headers are made from. They will last quite a while, especially if coated with a high temp clear. T-316 is probably the best stainless you can get, but very few headers are made from it. A good summary of different stainless steels can be found here.
    doh! I should have remembered that. That is what I was trying to get at. Thanks for explaining it better.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- trading in 2/11
    - 99 Contour SeVT <- 3L/NPG Turbo
    - 2k Contour SVT - #2137
  3. #13
    Join Date
    Sep 2009
    Chicago, IL
    Posts
    178
    Default
    All I know is that I am as excited as a kid in a candy shop about my Racebits... That said, I have never heard of anyone ever complain about stainless before... Looking forward to having no skin left on my knuckles one of these weekends...
    1998-E1 CSVT SilFro
    ***blu_fuz FOR PRESIDENT, 2012***
  4. #14
    Join Date
    May 2004
    Coon Rapids, MN
    Posts
    5,317
    Default
    Quote Originally Posted by Hydrargyrum View Post
    There are a few mustang guys that have headers and y-pipes made of T-409 as well as some Focus owners with a header that have complained... you can find some nasty looking pics, but that said they haven't corroded through from what I've seen so it's purely aesthetic.
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
  5. #15
    Join Date
    Jun 2006
    Center City, MN
    Posts
    2,888
    Default
    i didnt get to reading all of this thread, but i think i should say my 2 cents. take it or leave it.
    i had stainless headers on my contour (weapon R) and loved them. the only spot where i had any corrosion whatsoever was on the rear flange weld on the Y pipe, just the weld seemed to rust/corrode a little bit. the rest of them looked like new (minus a little "purpling")
    on snowmobiles, i have a little bit of experience with ceramic coating. the pros : it looks good and can be polished (usually comes polished by an automoated machine)
    "most" ceramic coatings are rated for 1400 degrees constant. the problem with ceramic coating is it is very easily damaged. also, oil will almost instantly dull and possibly damage the coating, which is a problem unless you do your oil changes very carefully.
    personally, if you are running a N/A exhaust system, i would go with a black ceramic coating, which is cheaper and won't be so ugly after it gets a scratch or two on it (you'll scratch your headers almost indefinately while installing them or installing an engine, unless your good "like me" lol)
    if you are running a turbo'd setup, i recommend using an internal coating such as a "swain tech" coating on the inside (2000+ degrees) and a black ceramic on the outisde with header wrap to finish it all off. stealthy, and functional.
    every "big boy" turbo setup i've seen has no coating on the downpipe, and just header wrap on it. i assume that would be because the turbo just gets too hot for any coating to stand up on the exit side of the turbo. i dunno
    R.I.P. CSVT "clockwork" totaled 10/29/10 n/a 3L 220whp 212 trq
  6. #16
    Default
    Yeah, I believe 409 stainless has a high metallic content making it a "magnetic" stainless. It's kind of like a cheap trash version of 304. I think alot of OEM so called stainless exhausts are made of 409, making them last longer than mild steel, but eventually they start looking nasty.
    321 or Inconel is for the ballers! Something you should look more into for your engine build Mike.
  7. #17
    Join Date
    Jul 2004
    Michigan
    Posts
    5,868
    Default
    Quote Originally Posted by mmc757 View Post
    With what msds was and still offering, its very common. I don't know anyone around my parts of town that have not seen rust start on there headers. I do agree with a well specialized coating, rust can be non existent. But what was offered at the time was only a wish of what we believed was what we were paying for.
    As you well pointed out the front header of mine was the most rusted of them all. The flange area was the initial culprit...and the spreading occurred. Now with all the money spent on coating and hoping it never occurs and etc etc. Stainless steel headers would remove the concerns forever.
    just my 2 cents.
  8. #18
    Join Date
    Nov 2009
    West Florida
    Posts
    172
    Default
    Thanks Harrry a lot of good information there. I think I now know which ones to get when I have the money.
    1998 Silver Frost SVT Contour #4049 - Sold
    1998 Corvette Coupe
  9. #19
    Join Date
    Oct 2006
    Central Iowa
    Posts
    445
    Default
    Good stuff, and mostly on par with what I was thinking. Now I just need to talk the wifey into why I need to spend money on a car I never drive!
    Erick --
    2000 SVT Contour
    0887 - Car Domain
    BAT | B&G | K&N | FSVT EAP | Hankook K110 | Magnaflow | B&M | Kenwood | Energy Suspension | Redline Tuning | Autovation
  10. #20
    Join Date
    Mar 2009
    Fort White, Florida
    Posts
    71
    Blog Entries
    7
    Default
    Not trying to resurrect a dead thread, but, those RaceBits headers and Y-Pipe are the best looking ones I've seen - for any car. Really stellar work.
    Makes me want to buy another SVT so I can do a 3L turbo'd set up on one, and use the RaceBits exhaust parts on a N/A car. Decisions... another CSVT or remain married...
    2000 Red Contour SVT
    2005 Black Ford Freestyle SE, 3.5L Duratec
    2005 Blue F-250SD Crew Cab, FX4, 3v 5.4l Triton
+ Reply to Thread
Page 2 of 3
Similar Threads
  1. Replies: 30
    Last Post: 11-01-2011, 02:25 PM
  2. Replies: 76
    Last Post: 10-29-2011, 03:13 PM
  3. Replies: 28
    Last Post: 05-18-2011, 06:57 AM
  4. Aluminum or Stainless Steel?
    By Tracedyahxy in forum Exhaust
    Last Post: 09-16-2009, 03:10 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
