Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: gasket
    Default gasket
    i need to replace the heads and gasket of my hybrid , taurus 3.0 with contour svt heads wath gaskets i need? 2.5 or 3.0
    the mechanic tell me that i need half set of gasket
    CSVT 98 #1862 of 6535 06/11/1997
    3.0,tw8mm,msds-h,2.5exhaust ,optimized y pipe, superchip,original svt cams, unorthodox udp,stage 1 spec clutch,optima yellow battery
    GTP 2002 no cat,original intake,mil eliminator,u bend deleted, 9.60 1/8 mille stock
    Use the 3.0 head gaskets for all 3L blocks.
    Rick
    Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
    Buckshot77@msn.com
    Misc 3L parts for sale
    buth the 3.0 don't have water pump on the battery side that not matter? i have installed the 2.5 heads i rember that the head gasket have diffrent shape
    As stated above use the 3.0 gasket. If you use the 2.5 gasket it will be about .400 too small.
    I have a set of new Motorcraft head gaskets for sale. $50 shipped for both of them.
    The ONLY 96 (engine) 3L - Dead at 12K miles
    Oval Port 3L with 1MM overbore and flowed/ported heads with all the other goodies.
    Those who can do. Those who can't teach.
    where are you located? i am in zipcode 92231
    Jul 2004
    Wisconsin
    2,235
    If you need new 2.5L heads, I have an extra set. PM me for details if your interested
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
    USE THE 3.0L head gasket with 3.0 heads or with 2.5L heads...
    <is there an echo in here>
    My project website
    Sep 2000
    7,331
    Or use the 2.5 headgaskets with the 2.5 heads on the 3.0 block and ensure very early headgasket failure. That sounds like fun to me.
    Jim Johnson
    98 SVT
    03 Escape Limited
  9. #9
    Quote Originally Posted by Big Jim View Post
    yeah sounds good here, anything woth f-in up once is worth doing again
    Toreador 98 CSVT #246 of 6535 (3L DONE!!!)
  10. #10
    Sep 2000
    7,331
    On a less harsh note, an explanation of why you cannot use the 2.5 gaskets. The bore diameter of the 2.5 is smaller than the 3.0. Using a gasket ment for the smaller diamer cylinder will result in some of the gasket hanging into the combustion chamber. Some of the gasket sealing design is probably in that area where it will not result in the appropriate "crush" to seal properly. More importantly, the gasket material hanging into the combustion chamber will very quickly burn up.
    As soon as you try to lay the 2.5 gasket onto the deck of a 3.0 block you would see the problem.
    Jim Johnson
    98 SVT
    03 Escape Limited
