Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: here's a GOOD question, help!
    Jun 2006
    Center City, MN
    2,810
    Question here's a GOOD question, help!
    okay. short and sweet, here goes:
    Can i machine the cyl. heads down on a 3L head on a 3L block to raise compression without piston to valve clearance issues? i plan on running CAT stage4 cams just to be clear there. let me know if you have any idea on what i can do. i do not know if the 3L pistons have valve releifs but i swear some pics ive seen had them. any ideas?
    98 CSVT-black. on it's second 3L swap. 219hp/211 trq
  2. Default
    So you're planning to run a super aggressive NA Cam as well as a turbo???
    US23
    Jun 2006
    Center City, MN
    2,810
    i dont have a turbo....... i plan on running a super aggressive N/A setup with a larger amount of nitrous on it.
  4. Default
    I see.... Its just all your threads about superchargers throwing belts, and I noticed talk about intercoolers in burritas thread.... Threw me off.
    US23
    Jun 2006
    Center City, MN
    2,810
    i'm working on the thomas knight setup but i am most likely selling it once i prove it's reliability. i'd much rather do the nitrous setup
    Jul 2001
    Burlington, ON
    4,077
    WOOHOO someone else might be the test mule instead of me .
    If I decide to go ahead and install the cams during next winter I was going to do pistons and all that good stuff but have decided the hell with it. Good luck with your project and gettign the cams.
    Aaron
    98.5 Black/Blue SVT#5906
    05 3L, ST220 UIM, Baers, D2's, OEM CF Hood, CF M5 Lip Spoiler, Pudmunkie Projectors, & lots more
    216.70whp and 198.39wtq (Old Dyno)
    05 SWP Legacy 2.5 GT-The DD.Cobb AP,Invidia Catless DP, Megan Racing CBE,K&N Typhoon.
    Jun 2006
    Center City, MN
    2,810
    lol. how much did you end up paying? also, there's 5 options? do you have the exact part# of yours?
    Jul 2001
    Burlington, ON
    4,077
    Quote Originally Posted by TRicker View Post
    I could tell but that would be to nice of me and after all I am a snob !............................. You have a PM.
    Aaron
  9. #9
    According to DemonSVT's site you can only safely deck the block or heads approximately .006" before valve clearance becomes and issue. Yes, the newer style 2001+ pistons have valve reliefs in them, but that still doesn't really help with your clearance when you're trying to remove enough material to bump compression. You'd probably be more effective by going the hybrid route using the 2.5 head with smaller chamber to raise the compression that way assuming you don't want to go the route of high compression pistons. Also, if you run a cam with any additional lift in it, you'll be bringing the valves even closer to the pistons when fully open.
    Rick
    Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
    Buckshot77@msn.com
    Misc 3L parts for sale
  10. #10
    man if you can only pull off .006" i wouldn't cut off anymore than needed to square the heads
    Toreador 98 CSVT #246 of 6535 (3L DONE!!!)
