Page 3 of 3
FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: Used car game
  1. #21
    Sep 2002
    SE Minnesota
    3,853
    Pontiac Bonneville SLE
    98.5 SeVT mods - Sold
  2. #22
    May 2004
    Coon Rapids, MN
    5,286
    Quote Originally Posted by elraido View Post
    Aren't those transmissions horrible?
    Quote Originally Posted by Pete D View Post
    Well it is a CD4E
    In all honesty that was what I viewed as one of the weakest points of the Escape (I owned a 2002 XLT V6 4WD). I never had any major problems with mine, but it was certainly the one major component I was worried about failing, and there certainly are enough horror stories of the CD4E out there. Around town I routinely had to keep the O/D off, otherwise it would upshift far too early and the gas mileage was not impressive. Thankfully they have replaced it on the 2009+ models.
    I still think it comes down to proper owner maintenance. If you do the routine tranmission flushes and follow what they state in the owners manual for use, you should be fine.
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
  3. #23
    May 2000
    Flori-duh, well at least my vote counts here
    3,138
    Quote Originally Posted by CSVT#49 View Post
    I disagree.
    There are plenty of contour owners that had CD4E failures despite better maintenance than what the manual suggests (their change interval is what 100k? lol) including myself. Same goes for Escape owners. I didn't experience a transmission failure in my Escape but I did have the shuddering issue from the torque converter and figured that if anything major would go on that vehicle (it was generally quite reliable, much better than my contour) it would be the CD4E. I had a tranny cooler too, fwiw (I believe they came standard on all earlier models with the tow package, and later V6 models with the CD4E)
    09 Mazda 6i Sport 6MT
  4. #24
    Mar 2007
    South Amherst, MA
    6,054
    Blog Entries
    7
    I disagree.
    When he says "routine transmission flushes," he means WAY WAY WAY more often than stated in the manual, but as for everything else, go by the manual. But sometimes it's just luck, too. I beat the crap out of my car and have only drained/refilled the tranny fluid twice (at one time), and that was at 85k miles. I'm up to 145k now...I have absolutely zero problems with my transmission except it doesn't like to downshift in subzero temperatures from 2 to 1 if it isn't warmed up (fixes itself really quick), and the TC doesn't like to engage in cold weather if I start it and shift immediately into gear without letting it idle down.
    Ian
    2012 Hyundai Accent hatchback
    1996 Zetec ATX - Retired but still running (barely)
    Aircougar Performance
  5. #25
    May 2000
    3,138
    Quote Originally Posted by zorrex View Post
    When he says "routine transmission flushes," he means WAY WAY WAY more often than stated in the manual, but as for everything else, go by the manual. But sometimes it's just luck, too....
    Which is way I stated "despite better maintenance than what the manual suggests"
    Both here and on Escape-Central everyone recommends changing the fluid much more often than what the manual recommends. On both of my CD4E vehicles I did it every 30k, despite that being a fraction of what Ford recommended because the ATF is far cheaper than the transmission itself. IMO, however, I think that it is the manufacturer's folly to recommend an interval that might result in increased failure rates.
    I kind of agree with you on the 'bad luck' thing if you read my post in the MB thread about reliability statistics.
  6. #26
    May 2004
    Coon Rapids, MN
    5,286
    Yes, I typical recommend it is a good idea to change fluid every 30k, which is what I meant by routine maintenance.
    -Mike
  7. #27
    Aug 2000
    Apple Valley, MN USA
    3,716
    Agreed. The manual is not designed to optimize the lifespan of components, as less maintenance is a selling point, and an adequate but not optimized lifespan is better for the manufacturer and its dealers. That said, in looking at the big picture (bigger than any car forum), Escapes do not have an unusually high number of transmission problems.
    "One problem with people who have no vices is that they're pretty sure to have some annoying virtues" - Dame Elizabeth Taylor
    Brad "Diva": 2004 Mazda 6s 5-door, Volcanic Red
    Rex: 1988 Mazda RX-7 Vert, Harbor Blue.
  8. #28
    Jul 2009
    Bangor, Maine
    1,310
    Some transmissions just have an inheriently crappy design. Look at the 96-95 Ford Taurus automatic transmissions. They were GARBAGE.
    2001 SVT Lightning #2839 - | Pulley | Tune | Bolt-ons |
    2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
  9. #29
    Oct 2007
    1,257
    Ended up with a 2002 Jeep Cherokee Laredo, RWD, 42,000 miles for $5k!
  10. #30
    Jan 2001
    The GREATEST country in the world
    2,132
    Quote Originally Posted by FauxhawkFox View Post
    Sounds like a good deal.
    Quote Originally Posted by Thomas Sowell
    One of the consequences of such notions as "entitlements" is that people who have contributed nothing to society feel that society owes them something, apparently just for being nice enough to grace us with their presence.
Page 3 of 3
FirstFirst 1 2 3
Similar Threads
  1. Looking for a name of a game
    By TourEnvy in forum Common Interests
    Last Post: 11-12-2008, 12:35 PM
  2. So why wasn't this game at E3?
    By KerryKool in forum Common Interests
    Last Post: 07-29-2008, 10:30 AM
  3. game over
    By 1FASTDAD in forum Eastern Canada
    Last Post: 08-07-2007, 10:27 PM
  4. Guess the car game....
    By TheMexicanJob in forum Pics and Videos
    Last Post: 12-07-2006, 11:11 AM
  5. Name the car game.
    By Auto-X Fil in forum Pics and Videos
    Last Post: 09-21-2006, 11:18 AM
