+ Reply to Thread
Page 2 of 6
FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 58
Thread: The Most Powerful N/A 3L Built?
  1. #11
    Join Date
    Sep 2009
    Chicago, IL
    Posts
    178
    Default
    Well, I am definitely set on buying my 3L, but to be honest I am still on the fence if I should do the Turbo. I read a whole bunch of stuff, and it just seems the sensible thing to do is go for the Turbo. I mean, when you're spending that much money, may as well go all the way.
    Right now the way I look at it, a good 3L will cost between 500-700 bucks. Tack on an additional 300 for the headers, and another 300 for the Y pipe. Plus there is the tune, and if you have to regasket the whole thing there is more. Plus the labor. And the hp is around 220.... I drove a few 3Ls, and they are definitely awesome compared to my stock 2.5 SVT, with an open exhaust and intake. But compared to the 3L/T cars, it's night and day.... I just don't think it's worth messing with the engine unless you can bump it up to around 300hp. And the only way to get there appears to be the Turbo route.
    Either way, by the end of next month, I will buy a 3L. Then we'll get to work on it.
    Thanks for the input guys.
    1998-E1 CSVT SilFro
    ***blu_fuz FOR PRESIDENT, 2012***
  2. #12
    Join Date
    Feb 2001
    La Crescent, MN
    Posts
    501
    Blog Entries
    1
    Default
    My CSVT is arguably the fastest N/A non nitrous build out there. Unfortunately, I have yet to have it Dyno'd but it has one hell of a wicked sharp torque curve. I estimate I'm in the 240-245 hp to the wheels range.
    Here's whats under the hood....
    =Performance=
    3.0L Duratec Engine (Hybrid build, 11:5:1 compression)
    Kinger PnP 2.5 SVT Heads with ST220 3L valves (5 angle valve job)
    Clevite Trimetal Rod Bearings
    SVT Cams
    SVT UIM (Extrude Honed MAX Honed Upper Intake Manifold) & (Jet Hot coated)
    SVT LIM (SHO-Source Extreme Port-Matched Big Bored Lower Intake Manifold)
    SVT 60mm TB, optimized
    SVT Focus 255 lph smart fuel pump
    Escape Oil Pan (improved baffle & drainback)
    DMD (Dual Mode Damper) Crank Pulley
    Sean Highland Motorsport Headers (long tube), (Jet Hot coated)
    Sean Highland Motorsport Y-Pipe
    CTA intake pipe, (Jet Hot coated)
    K&N 3530 Open Air Filter
    Custom intake heat shield (Pudmunkie)
    Bassani 2.5 cat-back exhaust
    Magnaflow High Flow Catalytic Converter
    Edelbrock muffler (resonator)
    Torsen T2 Limited Slip Differential
    SPEC Stage 1 clutch
    SPEC lightened flywheel (9 lbs)
    Focus MTX-75 Shift Tower
    Fully Rebuilt Transmission (New Syncro's, Shift Forks, etc)
    Oil Filter Relocation kit w/steel braided lines (FL-1Z filter)
    Oil/Air separator
    Superchip tuned, (Arizona Dyno Co)
  3. #13
    Join Date
    May 2004
    Coon Rapids, MN
    Posts
    5,293
    Default
    Kinda makes me want to run my 3.0L without the turbo just to see what it could do... I bet I could hit 300... just say'n
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
  4. #14
    Join Date
    Mar 2003
    Hamilton, ON
    Posts
    1,254
    Default
    250-300whp all N/A seems like a longshot in these cars...you will be running low comp, so wouldn't that mean you will make less power? My next 3L will be full boltons and everything to make as much power n/a as possible until next year when I start a boost build, but I'm only expecting to make TOPS, 230ish at the wheels (even that seems like a lot though, considering most people can hit 220 with everything)
    SOLD ---- Sean - 1998.5 3.0L CSVT #5906 - "MONSTOUR"
    Quote Originally Posted by rexxdoggy
    My intake right now is a heat soak muh fuh'in short ram gayness.
  5. #15
    Default
    hey cktour98 where do you plan on buying the 3l motor from(still looking on buying a good 3l from around here)
  6. #16
    Join Date
    Aug 2010
    Phoenix, Arizona
    Posts
    423
    Default
    I'm hoping I can start a N/A project when I get out of school and all the power will be in the machining because I think that is alot of fun. Now before everybody tells me it's a waste of time I don't think so because when you build an engine for a turbo alot of people overlook things because the extra 10 HP from a lot of work "isn't a big deal" when you go N/A yuo try to squeeze every last bit out of it. Like #49 is doing with the turbo build I hope to do the same with my N/A build and hold a record. I'm shooting for 300HP.
    99 Mercury Mystique LSVT Port matched 3L with some goodies
    74 Maverick 351 Windsor building 347 stroker
    86 Porsche 944 Turbo
  7. #17
    Join Date
    May 2006
    Plymouth,MI
    Posts
    3,054
    Default
    You guys are delusional...
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
    '99 SVT E1 BLK/TAN#0741
  8. #18
    Join Date
    Nov 2000
    Thornhill, Ontario
    Posts
    1,143
    Default
    Quote Originally Posted by Icefury View Post
    Show me a dyno sheet. Unless your, dyno-tuned or somehow ADC managed to pull a rabbit out of their hat with a mail order tune (I always lost power with them), you'll be lucky to be clearing 230whp. Just being honest.
    NOW: 2008 Aspen White STI
    TRACK: 2008 Legacy GT Spec-B (ex-Koni Challenge SRRT car)
    STOLEN: 2006 Aspen White STI
    Auto Parts For Sale.
  9. #19
    Join Date
    Aug 2010
    Phoenix, Arizona
    Posts
    423
    Default
    Quote Originally Posted by timeless420 View Post
    I have always been concerned about mail order tunes but it seems like a tune from joey is like the only thing I can go with. Any experience with him?
  10. #20
    Join Date
    May 2004
    Coon Rapids, MN
    Posts
    5,293
    Default
    Quote Originally Posted by RAD Merc SVT View Post
    He's been on here for a while and has been working on 3L's for quite sometime. He's done enough of them to know a thing or two. He is the only one that still builds and offers a turbo kit for our cars. He's a pretty good guy to work with and does what he can to make things right. While I have not contacted him about a tune for the turbo kit he sold me he has worked through a few issues I had and does a stand up job from what I've seen. Because of the amount of work I'm putting into my car I've kind of opt'd out of having him tune my car as I'm going to break my engine in on the dyno and tune it with DB Performance by my house (or at least that is the plan for now). There is a thing to be said about having someone working on the car in person versus over the computer looking at data logs. However if you are not going extreme I see no reason why a mail tune can't work the way Joey does it.
    -Mike
+ Reply to Thread
Page 2 of 6
Similar Threads
  1. NW Built
    By midnightmarauder in forum Northwest
    Last Post: 10-04-2010, 07:33 PM
  2. Look what we have here, one of the few ever built
    By AliasJerk in forum Pics and Videos
    Last Post: 07-09-2009, 02:59 AM
  3. Powerful braking system
    By Beowulf in forum Common Interests
    Last Post: 06-25-2007, 08:23 AM
  4. Built vs 3.0L
    By BrandonSVT99 in forum Forced Induction
    Last Post: 06-11-2007, 08:25 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
