I don't mind it, used to it now lol..but nothing pulling the bulb won't fix!
SOLD ---- Sean - 1998.5 3.0L CSVT #5906 - "MONSTOUR"
Originally Posted by rexxdoggy
Alex - Troll: '11 Mazda 2 GX w/ Convenience pkg Liquid Silver. (Fog's, Alum. Pedals, Rear Spoiler) Low, slow, loud...
They have one for the Focus. I don't think a Contour specific hub exists, at least from the name brands.
http://new.getnrg.com/products/quick...t-hub/srk-175h
Why do you need a spacer with the Focus hubs?
Sold- 98.5 Silver Frost #5979
Officially a troll. 2002 Suzuka Blue Honda S2000 on Works
Ok ill try to explain it the easiest way i can....basically...when the hub gets put onto the steering shaft, the shaft end isnt flush with the inside of the hub, so when you bolt the steering wheel bolt down, it tightens down to the shaft but since the hub isnt flush, it can wiggle around. So what i did was got a thick washer and used an air dremel to enlarge the hole, so it was bigger then the shaft and the bolt would tighten down to that, pushing the hub tight against the shaft and securing it
Pic update! First off, my Sparco hub + suede wheel! Todays job will be to modify the plastic panels to go over the hub
Then, I got my custom plates in...........its official now! 5906 is MONSTOUR! ...Also, lowered my coils some more
I also installed my endlinks, but no photos of that done.... im basically tucking half tire in the rear and just under half tire in the front, daily driven with the mirko![]()
More photos:
Heres my fronts, daily driven this way..tucking tire on 19s on all 4 corners
and my rears...
Just saying, since half your car is basically mine, I need to drive this one day... that is all. : P
Just saw this now.. sounds like a friggen plan! Btw, whenever you get it tuned, I'm tagging along. I'd actually like to get my Mazda Poo on a dyno just to see numbers, and compare it to other 2's that have been dyno'd. Feel free to laugh as much as you want when it's on there haha
