Photo tutorial on making your own gauges
Special thanks to savior, he gave me the idea and did a lot of the original work with files
If Anyone wants the PSD files that I used here they are.. Included are the ones i got from savior...
some are modified ... if you want the original spedo it's 5.psd (the one at the top)... there's bunch of files that i worked on with different versions in the zip file
http://dl.dropbox.com/u/28556637/5.psd
http://dl.dropbox.com/u/28556637/5.png
http://dl.dropbox.com/u/28556637/Gauges/Gauges.zip
... it'll let you skip steps 3&4 and some of touching up the guages
Step1: Remove gauges.
DO NOT DRIVE WITH THE GAUGES OUT>>> YOUR CAR WILL NOT CHARGE THE BATTERY AND IT WILL DIE>>
Step2: Remove the needles and peal the gauge faces off... (the needles pull straight up there are tools for it.. i didnt use any)
If you have a Mystique i can email the PSD files i used to do this The only thing thats different for the svt is the speedo goes to 150 or 60 instead of 130... If you have an svt you can ask saivor he did it for his.
Step3: Place the gauges on the scanner bed.. you can do it one at a time or all of them together (PAY ATTENTION TO THE SETTINGS) B/W will save you tons of time editing
Step4: Scan it in!(PAY ATTENTION TO THE SETTINGS)
