Originally Posted by
Tony2005
I read a recent post where someone did this (filling with polyurethane) and said it worked for them. And yes, it does increase the NoiseVibrationHarshness.
Not necessarily recent, but I did it to my old pre-98 when I put the stick into it in `04. I removed all the material from the roll resistors and completely filled them with poly. The engine mount and the trans mount were just filled over the stock rubber. Flexibility was reduced to almost nil. NVH went way up. If I could get the tires broke free they would spin like crazy, if they started to hook up and bounced, ALL of that would be transfered up the drivetrain into the cabin. Intresting experiment and I would probably do it again, but not on a daily driver....then again, women did seem to enjoy its idle. :naughty:
Wasnt terribly difficult to do, just time consuming. They need, IIRC, a week to cure completely at 70 degrees F. I picked up the urethane from McMaster-Carr.
Reason: spelling, duh
· Jon ·
· `05 E500 · `87 900 ·
