Best place to run power wire through firewall?
crocker_dave
Beaumont, TX
Hi!
I'm in the process of installing a stereo in my '00 contour and before I went digging under the dash, I figured i'd ask what the consensus is on the best/easiest place to run a power wire through the firewall? I'm really just looking to do what others have done in the past. Also, I don't mind drilling a hole if necessary.
Thank you!
Thank you FFE! I'm not used to this forum layout and I thought there were only 6 threads in the audio section until I noticed at the bottom where there is an option to display threads from a specific period of time. I guess the standard setting is to show threads for the current week. In the words of Homer Simpson...DOH!
