Results 1 to 3 of 3
Thread: Tranny Help in Portland
    Sep 2006
    Portland, Orygun
    1,393
    Default Tranny Help in Portland
    Howdy,
    Some of you may have read about my Tour blowing it's ATX tranny. If anyone can provide me with some help or advice on this please PM me.
    Thanks,
    Aussie Ford
    Proud Dad of a US Marine
    99 Contour SE Sport / V6 MTX
    95 Contour GL / 4banger ATX - Like no other.
    "its not shot it just grinds a little when going into third" - tjzollman 2/25/08
    Try to be as good a person, as your dog thinks you are....
    Dec 2002
    Portland OR
    1,851
    I did none of the work on my tranny myself. The place that dropped my manual trans and put it back in (after upgrades by a distant shop) was on Cornelius Pass Road in Hillsboro, and they have the '98 Ford service manual on their computer if that helps.
    Labor time dealing with that front subframe is not cheap.
    You'll want some way to raise your car, a todras service manual CD and good air tools if you try tackling a pull/swap in another used automatic/install yourself.
    MSDS SHO-shop Y custom 2.5" catback; xcal2; 63mm TB K&N 3530 Pud heatshield; Koni struts Aussie bar; THaines forks Quaife SpecII UR fly; DMD; UD pullies; Pole120 mounts. 92.03 trap speed: Just a daily commuter. SF/MB '98 SVT E0 #3159 8/21/97 178K miles
    Sep 2006
    Portland, Orygun
    1,393
    Quote Originally Posted by PDXSVT View Post
    Thank you, I have the CD and have printed the info for pulling / installing, but things are still up in the air as to what the plan will be. To me, it doesn't make sense to in stall a used tranny. Three blocks down the street after install it could just as well go bang again. Then all you have is the opportunity to do it again smarter. I think if I do it myself I'd like some help from someone that has done a tranny pull before. Then I would install a rebuilt one so that at least I'd have a warranty on it other than 30 seconds or 30 feet
