Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 22
Thread: Stock clock question
    Default Stock clock question
    is this thing supposed to be backlit, i have a CSVT parts car and swapped it out of that one and still doesn't light up at night. if it is backlit can teh bulb be replaced
    Toreador 98 CSVT #246 of 6535 (3L DONE!!!)
    Jul 2003
    Graham, TX: a place so nice, they rob your house twice! & Houma, LA
    3,194
    Yes, it is lit by a small bulb. Pop the clock out and the bulb is mounted on the back. Easy fix.
    If home is where the heart is, then I'm out of place.
    Quote Originally Posted by m!key
    IRingTwyce for president!
    Quote Originally Posted by ChattavegasSE
    I second the motion for IRingTwice for prez!
    Jun 2006
    Center City, MN
    2,800
    where can i get the bulb? mine hasnt lit up since the day i bought the car...
    98 CSVT-black. on it's second 3L swap. 219hp/211 trq
    Jul 2003
    3,194
    Should be available at any autoparts store or Walmart. Just pull the bulb and take it to the store with you.
    Quote Originally Posted by IRingTwyce View Post
    Wrong. You will have to modify the bulb or socket for w/e you put in there unless you go with a Ford bulb.
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    Jul 2003
    3,194
    Hmm. Looked like an average everyday bulb. Been months since I looked at it though.
    Sep 2004
    Tampa, FL
    1,976
    Upgrade to LEDs, color of your choice. Real easy if you know how to work w/ a soldering iron.
    '95 Contour GL, Zetec, Teal, ATX
    Born on Sep. 4, 1995
    100k+ miles!
    Quote Originally Posted by CSVT1214 View Post
    WRONG! If you bring the bulb to a good parts store they will be able to get the correct one. I got mine at Parts Plus and it was a direct fit.
    98 CSVT #2007 (RIP 07-02-08)
    98 CSVT #0147 3L hybrid, Koni's w/GC's, Baer 13" track kit, TCE 11.75 rear kit, OZ Supperleggeras, subframe connectors, tubular toe arms, Steeda short shifter, blah, blah, blah
  9. #9
    They had a bulb like this?
    The clock bulb has the metal contacts attached to the bulb. In order to install any other bulb, they need to be clipped off, the replacement bulb pushed into the socket with the leads on the bulb touching the pieces clipped off the original bulb. I didn't say it's not possible to do, because that's how mine is now with a red incandescent, and I used to have a LED in there before.
    So what did your bulb from the store look like?
  10. #10
    Jun 2005
    Pennsylvania
    2,227
    I've got a few from Ford in the past...it's like 5 bucks go get 1.
    -Justin
    Pittsburgh - City of Champions...again
    Steelers & Penguins 2009 Champs
