Results 1 to 8 of 8
Thread: Right turn suspensions clunk
    Default Right turn suspensions clunk
    I get a clunk in my suspension during right had turns. Any suggestions?
    1998 SE Duratec V6 ATX - Modified and Broken
    2001 Subaru Outback Sedan - Slow
    1994 Chevy Caprice Classic 9C1 Interceptor - SOLD
    1987 Chevy Cavalier RS Sedan - SOLD
    Aug 2004
    ILL, CHICAGO
    2,811
    Check if your spring is broken.
    03 Mustang Cobra Convertible # 476 out of 5,082
    93 Cobra
    01 Lightning
    99 LX Contour - Sold 2/23/09
    Default Suspension clunk
    Nope not broken, they are all brand new.
    Oct 2000
    Houston, Texas
    847
    maybe the sway bar ends or the bushings..
    if the bushings would bind would it make a clunk sound? It almost sounds like a rock in the tire type of noise.
    Well Might have narrowed down the problem.
    I used the "taller" nut on top of the strut mount on the front passenger side. Its leave quite a nice gap on the top of the strut tower, Would this my source of noise?
    I got to the local HS parking lot this morning and played around a bit but couldn't really identify anything. All the bolts are still there and appear tight.
    I beleive it may be 5 things. One is the mentioned above. 2) Is that in the process of all the banging I killed a bearing, and hearing the noise in turns is just pre-death noise. 3) Possibly the pinch bolt on the knuckle is not tight enough and the strut is moving up and down? (doubtful, but was a thought I had) 4) I have a cut/poorly warn tire and now that the new suspension is on the car Its making noise. 5) Binding of the ES bushings?
    The noise most definately sounds rotational related. Its a steady pulse when I can hear it. (which is why I am doubtful on # 3 and # 5)
    Any suggestions are welcomed. I I'll be dropped off at ESU tomorrow morning so I won't touch my car till next weekend. But I think I'm going to try and rotate the tires to see if there is any difference, mainly to see if it is cupping/irregular wear noise.
    Anyone elses thoughts?
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by ZeroHour View Post
    Yes. I had that once on a rear shock absorber and when I put on a rubber bushing to take the slack, the noise was gone.
    "Entiendo un poco espaņol"
    hmm the question now is, Is it possible to remove the nut from the strut mount while it is on the car? Or am I going to need spring compressors again and take the assembly off the car?
    I think with the weight of the car on the spring/strut mount it will hold itself in place if I release the nut. Not to mention I could just stop loosing the nut if the spring pushes up with it.
    Any ideas/suggestions? I still have the lower nut to put back on, so no trouble in that respect
