Results 1 to 4 of 4
Thread: Temp gauge
    Default Temp gauge
    I have seen posts but still need help. My temp gauge seems to work, but only under the first line before the N in normal. the needle moves to the line and that seems to be where it would normally be at r or m in any other car. fan kicks on as soon as it hits the line it seems. How do you replace the temp sender? where is it at? can i replace it myself? it is just connected to the engine and has nothing to do with the coolant right? it wont leak anything out? i dont know much but maybe i can replace it if i know where its at.
    Mar 2004
    Louisivlle Ky
    6,934
    it does read coolant temp so a little will leak out. the sender for the gauge is located on the underside of the thermostat housing.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    Jun 2004
    Plattsburgh, NY
    5,111
    FWIW, I've swapped out the gauge cluster itself multiple times, and I've changed out the temp sender, and it never made a difference. It always gets to a certain point and stops.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX
    Nov 2005
    Idyho
    915
    does your car heat up normally? if so you might consider leaving well enough alone
    Andres
    Contours are transportation, good transportation but just transportation at the end of the day.
Similar Threads
  1. Temp gauge wiring
    By UmmScott in forum Zetec Maintenance
    Last Post: 03-11-2010, 03:45 PM
  2. Temp gauge
    By pare_john in forum General Troubleshooting
    Last Post: 03-03-2010, 10:53 PM
  3. afteremarket temp gauge
    By 95pgt-t in forum Duratec Maintenance
    Last Post: 04-19-2008, 12:31 AM
  4. temp from the gauge in SVT
    By 97vulcan in forum Duratec Maintenance
    Last Post: 09-04-2007, 05:15 PM
  5. temp gauge not working
    By 96contour96 in forum General Troubleshooting
    Last Post: 05-07-2007, 11:44 PM
