mrspindlelegs
I'm playing with the idea of replacing the 2-bolt LCA subframe with a 4-bolt LCA subframe in order to use 4-bolt LCAs. The reason for doing this is purely "the 4-bolt design is better". The current subframe has to come out for a major overhaul project so if this swap is going to be done, now is the time to do it. I have determined the following so far:
1. The steering knuckles are compatible so they do not have to be changed
2. The 4-bolt LCA replacement subframe must come from a Contour/Mystique that has a manual transmission
3. There will not be any problems with radiator and roll resistor mounting as long as I conform to Item #2.
What I haven't resolved through pretty thorough forum searching are the following issues:
1. Does it matter if the donor car engine is a Zetec vs. the Duratec?
2. Does it matter if the donor car is a rod-shift vs. cable shift set-up?
3. Is there anything else that causes incompatibility problems when searching for donor cars such as "how the steering rack bolts on", "where other accessory items get anchored to the subframe", etc.?
Any help is greatly appreciated.
