Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: Car hasn't ran in 2 years
    Jun 2008
    Eastern Panhandle, WV
    42
    Default Car hasn't ran in 2 years
    My car hasn't been run in 2 years. Since I have a child on the way I plan to replace my wife's S10 with the Contour. Any suggestions what I should do before I try to start the engine?
    2005 MINI Cooper S
    2002 BMW 525i
    1997 Contour GL Zetec
    Nov 2005
    Idyho
    915
    Default Just check fluid levels
    Other than charging/ replacing the battery, checking fluid levels should be all that you need to do. If the car starts and continues to run, thank your lucky stars. Before driving it make certain that your brakes work, start out slow and if they work AND don't bind up, consider yourself very lucky.
    After you have the car running to your satisfaction, you might want to change engine oil, oil filter, gas filter, and at least brake fluid (brake fluid should be changed every few years, but no one does it, however after sitting 2 years even I'd do it). Check the antifreeze to see if it will handle your locale.
    Andres
    Contours are transportation, good transportation but just transportation at the end of the day.
    Jun 2008
    42
    Any tactics I can use in the (likely) event it won't start on it's own?
    2005 MINI Cooper S
    2002 BMW 525i
    Jun 2004
    Plattsburgh, NY
    5,111
    Quote Originally Posted by Wetworth View Post
    Assume you'll need a jump start, although the battery could be totally bad. I'm guessing your problems are going to lie more with settling issues... tires, suspension, brakes, etc. Another issue could be old fuel/water in the gas. It might be a good idea to add a can of dry gas and a few gallons of fresh gas to avoid any problems.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX
    Jun 2008
    42
    I'm taking jumper cables. I hope the battery is still good, it was replaced not long before it was parked. The tires need replaced as is, hopefully they'll hold some air long enough for me to diagnose the transmission issue that parked the car in the first place. I've been doing some reading and I believe that there's nothing mechanically wrong, just a bad sensor.
    2005 MINI Cooper S
    2002 BMW 525i
    Jun 2008
    42
    Dry gas sounds like an excellent idea. I assume the brake lines and tires will need replaced so the car is probably going on a trailer to be brought home, though, like I said, it would be nice to drive it a short distance.
    2005 MINI Cooper S
    2002 BMW 525i
    Nov 2005
    Idyho
    915
    Default The battery will be shot
    If you did not disconnect the battery it is shot, the clock draws current constantly. Even if you disconnected the battery it is probably shot. If it isn't, quickly get yourself to the lottery and buy a ticket.
    Adding some gas dry and a few gallons of gas is not a bad idea.
    But do it cheap, take the battery cables as you will surely need them. If the cars starts and runs okay, then buy a battery.
    Best of luck
    Andres
    Yep, I am constantly amazed at the number of people who think you can let a modern car sit forever without disconnecting battery cables. They can't believe that it will run down. Not only clock but keep alive memory and radio use slight amount of power at all times.
    Right up there with the number of people who check alternator by disconnecting battery while running. Plain goofy.
  9. #9
    Mar 2007
    South Amherst, MA
    6,054
    Blog Entries
    7
    I'd drop in a bottle of octane booster as well to help the gas. Either that or put in a couple gallons of premium to give it some slight help. Might want to inspect the spark plugs. They could be corroded from sitting for so long not running.
    Ian
    2012 Hyundai Accent hatchback
    1996 Zetec ATX - Retired but still running (barely)
    Aircougar Performance
  10. #10
    Feb 2009
    SEMO
    634
    inspect everything under the hood to make sure that there aren't any critters that have set up camp or used your wiring harness as a snack. check your airbox for nests.
    Green on Black '93 SHO 3.0 MTX *SOLD*
    T Red '98 Contour SE (Zetec)
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Local News: Car theft Victim finds his car and more
    By imnotacop420 in forum Common Interests
    Last Post: 06-13-2010, 10:14 AM
  2. Ran 98 out of fuel....
    By conbon in forum Zetec Maintenance
    Last Post: 06-04-2010, 09:49 PM
  3. Just ran over a Bear!
    By MattB in forum Common Interests
    Last Post: 05-17-2010, 12:54 PM
  4. Replies: 29
    Last Post: 06-09-2008, 03:59 PM
  5. 7 years
    By ryanblacksvt in forum Common Interests
    Last Post: 03-05-2008, 11:26 AM
