current mods consist of cool air intake, 2.5in custom bent exhaust, aeromotive adjustable fuel pressure regulator set to 40psi, FR wires, MSD coil pack.
yeah but i dont have access to the school dyno anymore so im not sure how im gonna go about doing that. if i knew exactly what caused it then i might be able to fix it without the dyno.
What type of fuel were you running? Premium unleaded would smooth out the graph a bit more.
i was just running straight shell 87 octane
Your so lucky that you can use the schools dyno. Impressive numbers, it just means my 4 cylinder is alot slower than I thought.
03 Mustang Cobra Convertible # 476 out of 5,082
93 Cobra
01 Lightning
99 LX Contour - Sold 2/23/09
Yikes! At least bump your FPR up 5psi. It even looks like your power dips when your AFR peaks around 3700rpm.
Do you have any kind of data logger? Your fuel trims are probably maxed out.
HTH,
BP
--'96 GL * MTX Zetec * Tan with more and more mods-- <<Project Car
--- '06 Mazda 6s * 3L Duratec * 6-speed ATX * Lapis Blue ---
FOR SALE >> T3 Super 60 Turbo - Coated Focus Manifold - FRPP Head - '00 Zetec Engine << FOR SALE (PM me)
i do not have any kind of datalogger. however when i looked at long term fuel trim after installing the FPR it actually showed the PCM taking away fuel.
as for tuning i would say that yeah its a tuning issue cause i have no tune. its a completly stock pcm
You have to watch out though. The Long Term Fuel Trim is opposite from the short term. It's weird. A positive STFT means that you are running lean (it's adding fuel.) BUT a negative LTFT also means that you're running lean. I don't know why it works that way. Kinda funky.
See if you can find a local CEG'er with some decent data logging software.
BTW, did you move back south yet?
BP
