During the recent holidays I installed the front struts & springs from the Koni Suspension Kit that I purchased a few months ago I also replaced the LCA's (4 bolt type), Tie Rod Ends, Strut mount bearings & Stabilizer Bar Rubbers. All went well with the installation & while I am not very happy with the lower stance of the vehicle the ride & handling has improved & I suspect it will improve even further after installation of the rear struts & springs. However, I am now having a problem with my ABS light, it will not go out & checks of the wheel sensors shows no obvious signs of damage. Consequently I am using this medium to ascertain whether anyone has any advice/comments on how I can diagnosis this problem i.e. what is the appropriate tool to use (I have located the data port). I have access to a OTC Genisys scan tool, however, it's does not have the required connector for the ABS data port.
All advice/suggestions will be greatly appreciated.
Bookmarks
