One of the brake lines to the rear brakes is leaking right where the lines run under the passenger side door and start upwards into the wheel wire/fire wall, with no room to make a new flare.
So I want to replace the line starting at the master cylinder connection, run the new line down and over to under the door with room to make the flare connections. Since I don't have to follow the current path, what is the easiest route?
a) is there an easy way to find out WHICH line is leaking? It is not possible to trace them behind the motor
b) If I can't determine which one, I would replace both rear ones?
c) at the master, which are the rear connections?
d) what is the easiest way method to reach and loosen the connection at the master?
d) can I prevent that the system drains out and needs complete bleeding (or is that needed anyway)?
f) what is the line size to be used?
g) what is the connector I need to connect to the master so I can get the right one
Thanks.
Thanks.
