The brake light is on in my car constantly. its not the parking brake switch becuase its not connected. Its not the low fluid level sensor becuase i have plenty of fluid and i also jumpered around that. What other things can set off that light?
Doesn't the brake light come on as a signal when there is a problem with the ABS module? (failure to pass a test, etc)?
Probably all the ABS sensors Eurotrash broke despite my advice.
what the hell i don't know about you clowns seriously
Don't rope me in with him!
WTH did I do to be in on this?![]()
LOL not you ray, Toddles and Eurotour
Ill check all the abs sensors when the car comes back from ford for recalls
Check in this order:
1) Brake fluid level
2) E-brake switch
3) ABS module
ABS sensors will not cause this fault. A hard fault in the module can.
The ABS light comes on if the module fails a self test, not the BRAKE light. However, if both lights are on, the BRAKE light must be resolved first since a fault in its operation generally automatically causes an ABS fault light.
Steve
98 Contour SE Sport 2.5 Duratec ATX Was the wifey's car, now it's mine - 170K
89 Taurus SHO - Retired at 249K miles
94 SHO ATX - 240K
1997 F-150 5.4L E4OD - The Workhorse 170K.
2007 Mariner AWD - Wifey's new ride.
Thanks, its gonna be the abs module, i checked everything else.
anyone have a pic of where the abs module is located?
Need year and approximate production date.
Most likely its buried in the engine comapartment between the brake booster and the top of the rack on the driver's side.
Steve
94 SHO ATX - 240K
