Results 1 to 9 of 9
Thread: Lost
    Question Lost
    Hello everyone
    My tuner wants me to do a log while going from 1000 rpms to the revlimit while in 3rd gear.(At wide open throttle) . Doesn't specify how. Just says he doesn't care how just to do it. So much for the help!
    So how in the world would I do that unless I am on a dyno? I tried starting in 1rst untill about 10 miles/hour(or about 1200 rpms) then shifting into 3rd but the engine allmost wants to die.
    So untill I hit at least 2000 rpms I cannot go WOT to the rev limit in 3rd gear .
    Anyone have any experience with dataloging in 3rd gear?
    Thanks
    97' ZETEC Contour, 2.0L, 16V , DOHC ,VIN 3,MTX75 ,5 speed
    Mods: JE 10.5:1 Pistons,Eagle Rods,Custom SVT Longtube headers,Spec Stage 2 clutch, Air intake,Mangaflow full exhaust,ThunderVolt 8.2 ,Accel coil,Aeromotive FPR,24# inj ,VMP tune with X3.
    Nov 2009
    cleveland ohio
    172
    umm well im just gonna take a wild guess and say, since you dont have a dyno on hand; why not just jack up the car and do it in the air?
    Dec 2001
    Gales Ferry, CT
    24,471
    Blog Entries
    93
    Quote Originally Posted by Antec View Post
    um, no. chances are running to redline you will break something. plus you need a load on the car to see how its going to respond.
    so unless your going to be breaking speed limit, or can find a closed road, you will have to hit the dyno .... or start at 2k rpm.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
    Mar 2004
    Louisivlle Ky
    6,934
    this is what you should. ^
    there is no reason to go down to 1000 RPM so starting at 1500 or even 2000 will be fine. if he refuses to help you then i suggest finding another tuner.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
    I was thinking about jacking up the fron tires and doing this but there will be no load on the car like you said BrApple. I managed to do this yesterday at around 1200 rpm while starting on a freeway ramp which is a bit downhill then levels out onto the freeway. I hit 85 mph and 6791 rpm until the fuel cut-off kicked in. I started in 1st and went to about 15 mph then shifted into neutral untill rpm dropped to about 1200 then shifted into 3rd and went WOT. I agree with you striker2..2000 rpm is doable but not 1000. I'll keep you guys updated.
    Thanks
    Jul 2009
    Bangor, Maine
    1,310
    Quote Originally Posted by acontour View Post
    Thanks
    Wow, your tach is accurate!!
    2001 SVT Lightning #2839 - | Pulley | Tune | Bolt-ons |
    2000 SVT Contour #1541 - | K&N | FSVT EAP | Hankook K110 | Y-pipe | RSTB | Energy Suspension |
    Quote Originally Posted by Smokinjoe View Post
    It was actually 6781 rpm at 85.25 mph. I just checked my datalog again.. I guess it's supposed to be at 6750 or 7000 rpm so
    If you are being sarcastic then enlighten me why is not accurate.
    Dec 2007
    Peoria, IL
    504
    The redline is supposed to be 6750, not the fuel cut-off.
    1998 T-Red SVT 115,000 miles (Died 9/01/08)
    2000 Tropic Green SVT #396 - 04 3L, HMS Trans, Wilwood BBK, FSVT Rear BBK, Koni/H&R...NPG Turbo Kit (JUNK)
  9. #9
    I'll check my 2nd datalog to see when it kicked in. The tach might of showed 6750 but the log showed 6771 or 6781. Either way I can live with it
Similar Threads
  1. Lost my Key!
    By bhiggs89 in forum General Troubleshooting
    Last Post: 02-02-2009, 11:17 PM
  2. New Lost
    By Phoenix33 in forum Common Interests
    Last Post: 01-22-2009, 08:00 PM
  3. Im So Lost!
    By Goonz SVT in forum New England
    Last Post: 05-31-2008, 01:01 PM
  4. So I lost my job.
    By PENē in forum Northeast
    Last Post: 12-31-2007, 03:01 PM
  5. Lost 1st, 3rd, and 5th
    By iBrent in forum Transaxle
    Last Post: 06-02-2007, 04:24 PM
