Results 1 to 3 of 3
Thread: Suspension Overhaul
    Aug 2004
    Renton, WA
    1,477
    Default Suspension Overhaul
    So I have a BAT Kit I will be installing in a few months, what else should I look at replacing on a 75k old SVT? Thanks.
    -tropictour
    2000 Contour SVT
    Tropic Green
    SHO Shop CAI, BAT Pipe, PS/Alt. UDP's
    Bassani, WR Headers/Y-pipe
    Full HMS Trans./Fidanza Flywheel/SPEC Stg. 1
    Sep 2000
    7,295
    Front strut bearings would be a good idea. Camber kits will give you adjustability for caster and camber should you need it. Beyond that it depends on the condition of other things. If the front A arm busings or ball joints are worn this is a good time to replace the A frames since you will already have part of them loose to install the struts.
    Jim Johnson
    98 SVT
    03 Escape Limited
    10 Fusion Sport
    Dec 2001
    Gales Ferry, CT
    24,479
    Blog Entries
    93
    sway bar bushings ..... also at least clean and re-grease the front strut bearings if you don't replace them
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 2k Contour SVT - #2137
