Results 1 to 6 of 6
Thread: Does battery change on keyless remote result in reprogramming?
    Default Does battery change on keyless remote result in reprogramming?
    Here's a stupid question - if you change the battery on your keyless entry fob, do you have go thru the reprogramming rigamarole again? I have an aftermarket Remocon RMC-105 fob that I bought a couple of years ago after losing an OEM keyfob for my '96 Mystique. I need to change the A23 battery in it, and can't find any info on whether it will need to be reprogrammed (you know, the paperclip jumper behind the glove box).
    Feb 2008
    Vermillion, South Dakota
    1,749
    not usually.
    I strongly abide by the motto, "Safety third."
    I thought what I'd do was, I'd pretend I was one of those deaf-mutes.
    Dec 2001
    Gales Ferry, CT
    24,944
    Blog Entries
    93
    never had to reprogram any remotes when changing the batteries.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- traded in 2/13
    - 2k Contour SVT - #2137
    Works fine now. The old A23 battery was down to 11.7 volts; the new one hits 12.6 V. I've had 12V batteries in garage door openers that still worked at as low as 7 volts, but I guess this system is just twichy-er.
    Jun 2003
    Kitchener, Ontario
    803
    I believe the car is programmed to the remote, not the remote to the car. So the code for the key fob is actually stored in the car.
    1999 Silver Frost SVT - #2603/2760 Aug. 10, 1999.
    1998 Black SVT - #3035 Re-born 3/12/09
    1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
    1995 Ford Contour V6 MTX-sold @ 214,000km
    Nov 2003
    Plainville, CT
    8,140
    Quote Originally Posted by KyleH View Post
    Yup. There is no actual programming in the remote. You can program the same remote to multiple cars if you wanted to.
    1998 SVT Contour 3L (B/MNB) #542 (His)
    2000 SVT Contour (SF/MNB) #1533 (Hers)
    2003 BMW 540i M-Sport (6 spd)
    2002 Cougar XR - XR Racing Red
    2002 Lexus IS300 SOLD!!
Similar Threads
  1. Remote keyless entry
    By Feimer74 in forum General Troubleshooting
    Last Post: 10-17-2008, 07:19 PM
  2. need help setting a keyless remote
    By kennyssilver99svt in forum General Discussions
    Last Post: 04-13-2008, 08:32 PM
  3. Remote Keyless entry?
    By s.rich06 in forum General Discussions
    Last Post: 06-05-2007, 12:52 PM
  4. keyless entry remote
    By 2slowtour in forum General Troubleshooting
    Last Post: 10-22-2006, 09:18 PM
