Page 1 of 3
1 2 3 LastLast
Results 1 to 10 of 23
Thread: so has anyone figured out how to...
    May 2006
    Glen Ellyn, IL
    2,452
    Default so has anyone figured out how to...
    so has anyone figured out how to put the caliper retaining springs on without scratching a painted caliper????
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Nope. Do a touch up.
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    may still end up scratching the paint but try some vice grips ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Jun 2006
    Allentown, PA USA
    1,280
    Quote Originally Posted by todras View Post
    Agreed. Just work at it gradually. You're going to end up scratching it no matter what though.
    It also helps to have a second pair of hands to hold the top part of the clip in while you work on the bottom section.
    |Aaron|
    '98 SE 2.0L
    '99 SVT #1530 of 2760
    May 2006
    Glen Ellyn, IL
    2,452
    ok yea if tryed toching up after they are on and it just dosnt look perfict. lol
    Feb 2006
    lancaster PA
    2,622
    haha mine went on and didnt scatch dont kno how that happened?
    Good Twin-1999 Black/MNB SeVT. Short throw, trubendz exhuast.
    fiberglass side skirt GB. add your name already!
    May 2006
    Glen Ellyn, IL
    2,452
    Quote Originally Posted by yamaha racer 686 View Post
    lucky
    +10
    Jul 2004
    Minneapolis, MN
    512
    Ill tell you exactly how to do it. If your right handed. Put the left side of clip in hole about 1/2 to 3/4 in, NOT ALL THE WAY IN, hook the underside of clip on caliper in postion like it should go, hold the bottom of the clip on the caliper with your middle finger then in your right hand you should have like a needlenose type device at the ready. line up right side grab that lil piece of wire like a man with those needlenose hold right bottom on with thumb of left hand. Now torque that wire into that hole and "pop" it into place. Done. No scratches. Now shake it off.
    1998 Contour Svt Born 5/12/97 #897 of 6535 or 2487
    (depends how you look at it)
  9. #9
    May 2006
    Glen Ellyn, IL
    2,452
    hahahah ok sounds good. thanks guys
  10. #10
    May 2006
    Glen Ellyn, IL
    2,452
    ok i know this sounds dumb but is this the tool for the springs? if so, i have it. i have only used the other end for drumbs.
    http://www.partsamerica.com/ProductD...tnumber=648404
