1995 Contour 2.5 V6 Duratec
vtraudt
We are in need for a usable wire harness; on ours, there are more bare wires than you can count, insulation literally falling off.
If you have one...
If you know someone who has one...
If you know where to find one...
...PM or post. I'm also often on NECO.
I'd be willing to take someone's "bare wire" harnesses, as long as the connectors are intact. I could reconstruct a new one if I had the old to use as a pattern. Unfortunately, the previous owner of my '95 did a hodgepodge cut and splice that makes it no good as a pattern.
Anyone with an intact "bare wire" set of harnesses they would part with. I might be inclined to build two harnesses if I had a suitable pattern to follow.
