Results 1 to 8 of 8
Thread: Deep Sound and Vibration
    Default Deep Sound and Vibration
    I bought my mystique in Aug 2005 and it has always made a deep sound when driving.
    First, I though it was road noise from the tires and maybe I needed an alignment. I got my new rims and tires and I got an alignment, but it didn't go away.
    Second, I thought it was the exhaust b/c the flexpipe was broken, but when I replaced it about 6 months ago the noise didn't go away.
    The noise and vibration gets louder as you turn the steering wheel to the left and goes away when turned to the right. I am beginning to think it is a motor mount.
    I have no trouble turning the wheel or any problems like that. There is also no rev range, it only matters the the car is moving.
    Anyone have any ideas or anything I can check for. I am very close to bringing it to the dealker so they can look at it. I have had 4 diff people who know cars look at and they have no idea.
    It is a very deep sound, low frequency and vibrates the interior, I do not feel it in the brakes, gas, or steering wheel.
    Thanks
    2000 Mercury Mystique
    ED Molded Bodykit
    Lots of Custom Mods
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    wheel bearing, the noise going away when that side is loaded iirc
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    How hard is that to replace?
    Will it cost alot?
    How long do I have until the car is not driveable?
    ED Molded Bodykit
    Lots of Custom Mods
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    you can go awhile but I wouldn't let it go to long ... the bearing should run about $50 ... you need to remove the hub and have the old bearing pressed out and the new one pressed in ...
    - 95 Mystique LS
    Mar 2004
    Louisivlle Ky
    5,206
    it does sound like a wheel bearing. you got it backwards BrApple. when you load the bearing is when it makes noise. so by going left your loading the right bearing and vice versa. i would just replace both of them. then you shouldnt have to worry about having the other one go out later.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    I let mine go long enough that it all you could hear was grinding metal, and could see metal flakes on the inside of the rim. Don't do that. I think it ran me about $120 to have a shop do it.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX (for sale, see classifieds)
    I'll be bringing it in to have it looked at this week. I will let you guys know.
    Its funny, I got quoted $480 to change both of them. That is outrageous. It might be a few other things, but thanks for the help and keep it comin!!
    Ill let you know what happens soon.
    ED Molded Bodykit
    Lots of Custom Mods
    Sep 2000
    Louisville, Ky
    9,565
    If you let it go to long, it will ruin the whole knuckle assembly. I found that out the hard way.
    Jim Hahn
    1999 Tropic Green SVT Contour
    364 whp, 410 wtq @ 4,700 rpm
