Page 1 of 2
1 2 LastLast
Results 1 to 10 of 15
Thread: amp info
    Jul 2004
    Wisconsin
    2,235
    Default amp info
    hey huys... I don' tknow much about audio, but I want to increase my knowledge. One thing that constantly bugs me is not knowing the differnces between amps. Not brands, but mono, 2 channel and 4 channel amps.
    Does anyone know of a site that explains the differences and what amp is recommended for which type of install? Everything I have found off hand really hasn't helped. I'd appreciate it.
    2000 Contour SVT
    SF - #542 of 2150
    3L: SVT Cams/LIM/UIM/Optimized TB/MAF
    HMS Trans: Torsen/SS Forks/Synchros/Zetec FD
    Mods: K&N/MSDS Headers/Trubendz Y & Catback/DMD/Steeda Short Throw
    Tuning: Xcal2 with PRP
    Susp: Bat Euro Kit
    First of all what are you wanting to do?
    Quote Originally Posted by svttouruofl View Post
    This is needed first.
    1. If your going to amp your highs your going to want a 4ch amp.
    2. If your going to power a set of subs your going to want a Mono amp.(BEST AMP FOR SUBS.)
    Anything else you would like to know?
    Joe
    04 F-150 4x4 loaded Red Magie side exit exhaust, Edge Evolution tuner.
    07 600 ninja was blk now is yellow aka bumble bee, Two bros slip on.
    Want your headlights clear again? PM me for details.
    Jul 2004
    Wisconsin
    2,235
    basically i'm not looking to do anything. I want to learn about audio stuff so i can expand my knowledge base as far as automotives are concerned. I mean, I can and have hooked up systems before, but it was with stuff people have already bought, and I know nothing about what kind of amp should be used for hat, what kind of power should be driving a certain power rated sub, etc. Just wondering if anyone knows a good website that explaines some info on car audio.
    2000 Contour SVT
    SF - #542 of 2150
    Susp: Bat Euro Kit
    Apr 2005
    Pillaging in Freedom, PA.
    3,875
    Try www.crutchfield.com . They have a "learning section" that explains the basics pretty well. Maybe not the best prices, but their info is good.
    Scott,
    1999 CSVT, Tropic Green, #2068
    "And that was all without even a single drop of rum" -Captain Jack Sparrow.
    If I'm a moderator, why don't I have groupies!?!
    Feb 2006
    lancaster PA
    2,622
    really good prices at http://www.sonicelectronix.com/ and if ur going with subs you want a amp that is mono and class D. also look for rms in all speakers and subs. Cause if the amp doesnt equal or pass what the rms is on the item it runs then you will get clipping in your audio and it will damage your system. Just letting you kno sum stuff if uwant to kno more or have questions pm me.
    Good Twin-1999 Black/MNB SeVT. Short throw, trubendz exhuast.
    fiberglass side skirt GB. add your name already!
    Jul 2004
    Wisconsin
    2,235
    I already have a system. Just looking for some information so I can learn more, because I really dont know much. I appreciate the links guys.
    2000 Contour SVT
    SF - #542 of 2150
    Susp: Bat Euro Kit
    Aug 2001
    Waterbury,CT
    4,847
    yes theres a link that gives audio explanations. i'm at work now and will post it later. i've found it pretty informative
    Hugo 99 contour svt #1750/2760
    my profile
    some pics
  9. #9
    Aug 2001
    Waterbury,CT
    4,847
    my profile
    some pics
  10. #10
    Well a mono amp focus' on the low bass. 2channel is usually only for two speakers that you hook up but you also can use them for bass. 4 channel is for four speakers that you want to hook up.
    anymore questions jus ask about anything audio
    2001 Mustang GT
    Flowmaster
    Bullitt 17in Rims
