Page 1 of 2
1 2 LastLast
Results 1 to 10 of 17
Thread: 4 bolt LCA's...better way???
    Aug 2003
    DFW (Keller, TX)
    2,487
    Default 4 bolt LCA's...better way???
    Isn't there a better way or a mod or something? I mean I gotta spend an arm and a leg for factory ones (no pun intended) and then the bushing can break again?
    Has anyone done anything other than replace them?
    98 SVT # 692 05/02/97 3L turbo....SOLD!!!
    DD: 2005 Honda Civic 39.7mpg (best so far)
    Wife's car: E53 X5
    garage: E39 M5
    Feb 2006
    lancaster PA
    2,622
    did u check bat? i think they sell the lower control arm or u can just get seperate bushings that bolt on if im wrong ill get corrected soon enough
    Good Twin-1999 Black/MNB SeVT. Short throw, trubendz exhuast.
    fiberglass side skirt GB. add your name already!
    Aug 2003
    DFW (Keller, TX)
    2,487
    BAT is more expensive than Ford at a discount....Bill Jenkins
    Wife's car: E53 X5
    garage: E39 M5
    May 2006
    Glen Ellyn, IL
    2,452
    is this a 2 bolt? i havent looked on my car yet but i know i need new ones.
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
    Aug 2003
    DFW (Keller, TX)
    2,487
    yes it is....2 bolt. They are the cheap ones...48 a piece through Bill Jenkins...with a ball joint!!!
    Wife's car: E53 X5
    garage: E39 M5
    May 2006
    Glen Ellyn, IL
    2,452
    yea thats were im gettin mine. im pretty darn sure i have 2 bolt, o god i hope so.
    Aug 2003
    DFW (Keller, TX)
    2,487
    if that is a pic of yours...then for sure it is a 2 bolt.
    Wife's car: E53 X5
    garage: E39 M5
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    there was one member that upgraded the 4 bolt arms ... he has pics on his car domain site ... I meet him but I forget who it was ... he built a 3L for his son and daughter ...
    as for cost contact Nima (96blackse, iirc) he has them for a good price ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
  9. #9
    May 2006
    Glen Ellyn, IL
    2,452
    Quote Originally Posted by stilov View Post
    no those arnt my pics.
  10. #10
    Jun 2000
    Hammertown, Canada
    611
    Exclamation
    This issue has been debated on these boards "ad nauseum". 4 bolt A arms are clearly superior to the 2 bolt arms with 2 exceptions-cost & ease of installation.
    To the best of my knolwedge, there are no aftermarket bushings available for either design. Someone on the boards had his Dad fabricate solid metal bushings for the 4 bolt arms but they will be harsh, no doubt about it. Someone at NECO used to sell/make tubular 2 bolt arms with rod ends. They'll be harsh too, but if your car is a "track queen" who cares?
    I've also seen some on the MEG boards which were 2 bolts with poly bushings, but unless they're a low durometer my guess is they'd simply pull out of the sleeve.
    Ford saw the light and went back to the 4 bolt A arms on later Cougars.
    96 SE with '01 3.0. Overbored 62mm throttle body, custom LIM, double honed SVT UIM, SVT cams, headers, custom Y pipe, custom mandrel bent SS 2.5" exhaust, Quaife, torque brace and custom frt & rr suspension.
    I make custom suspension parts.
