Duratec mega fuse location
Murtaza
Jersey City, NJ
So I've got a 95 Contour SE with a 99 Cougar V6 with the MTX swapped in and a couple of problems. One being the battery light is on and I'm trying to find out where the megafuse is. Also the speedo and fuel gauge is dead so where should I be looking for the speedometer sensor? thanks for any help
I replaced the speedometer/dash when I put a 96 engine in my car. If you need a vss sensor assembly or cable. I have those and the original cable speedometer dash. I found that the newer elctronic speedometer/dash works fine in my car.
