Results 1 to 4 of 4
Thread: ? about ES trailing arm bushes
    May 2006
    Glen Ellyn, IL
    2,451
    Default ? about ES trailing arm bushes
    ok i have yet to put mine in. my question is will they start making noise/ squeak after a bit? my ES sway bar bushes started to squeak after not even 1000 miles. and theres like no way to take apart and re-grease the trailing arm ones.
    thanks - jon
    -JON 99 CSVT T-Red. #2437
    www.myspace.com/ripscottfrost
    Jun 2000
    Hammertown, Canada
    611
    Lightbulb
    Yes they'll make noise and extra harshness too. Been there, done that and went back to the stock rubber (at least in the trailing arms).
    Poly is fine for the lateral arms but don't use it for the longitudinal (trailing) arms. Of course, this is my informed decision. Others here may not notice the extra NVH or don't care about it.
    My .02.
    96 SE with '01 3.0. Overbored 62mm throttle body, custom LIM, double honed SVT UIM, SVT cams, headers, custom Y pipe, custom mandrel bent SS 2.5" exhaust, Quaife, torque brace and custom frt & rr suspension.
    I make custom suspension parts.
    May 2006
    Glen Ellyn, IL
    2,451
    ok thank you for your input. i will not be putting them in. thanks again
    Aug 2001
    Waterbury,CT
    4,847
    brad, so u think its not much of an issue to use poly on the 2 control arms( the thick and thin rear ones). and dont do it for the trailing arm?
    Hugo 99 contour svt #1750/2760
    my profile
    some pics
