I'm looking at a 96 Zetec ATX with only 55K miles on it.It has an overheating problem but otherwise a very clean car.Are there any common problems for this engine that would make it overheat with such low mileage?
water pump, thermostat.. Clogged radiator.
98' Contour SVT #2037- 132k, (blk/mnb) 04' 3L ported w/ SVT cams
Chevrolet Blazer- 111k, mostly stock
Turn on heat (warm air = water pump) or hot air coming out=thermostat, radiator, head gasket, bad gauge or gauge sender. A real time scan will tell if the engine is really overheating.
"Entiendo un poco espaņol"
