The 2.5 Duratec block was designed by Porsche, then massaged by Ford. The heads and intakes were designed by Cosworth.
The Taurus SHO V6 was designed by Yamaha, but it's not even similar at all to our Duratec.
All 2.5 Duratec V6 models have a dual-stage intake manifold. It's not "the same" as the SVT Focus, but the technology is the same. 1995 models used a vacuum-operated IMRC, then everything after that used a mechanical IMRC, probably the same part number as the one used in the Focus.
looks like its probably a pre-production mk1 Mondeo from what I can see of the corner lights and headlights.Is that an early duratec in a scorpio or something?
We had someone that was involved with the development of the Duratec a while back that said that Porsche Engineering (a separate group from Porsche Automobiles) aided Ford in developing the engine. If you pay attention, you will notice that is is a derivative of the Ford modular family sharing design concepts with the DOHC Cobra and Mark VIII V8 engines.
Cosworth helped resolve block casting issues related to the interface with the cast iron cylinder liners.
Make no mistake, it is a Ford designed engine using other entities for design support.
Engine Builders Magazine said:While Ford has reaped the Duratec's benefit, it was not an original design. The primary input for the design of this engine was Porsche, which was already developing the configuration for other purposes. Porsche sold the engineering to Ford and Cosworth, the dominant force behind the cylinder head design. There is actually a 6.0L V-12 Duratec configuration used in the Aston Martin, which is custom built for each vehicle by Cosworth in England.
I was under the impression that the duratec is based off of engine designs porsche had developed then later sold to Ford and cosworth
I would say that is a Porsche with a duratec in it. Probably one of their testing mules.
