Page 1 of 2
1 2 LastLast
Results 1 to 10 of 13
Thread: getting the front door panels off...
    Default getting the front door panels off...
    i'm in the process of putting a new head and speakers all around and i got a good deal on some 6x8 infinity speakers....so my question is how do i get the driver and pasenger doors off?...
    i got the rear door panels off fine and speakers installed...but i have all the screws out of the drivers side and it still seems attached at the door handle and loose everywhere else....i heard you have to pull up not out but i think there might be one or two screws left...any ideas?
    (in surgery for Bagged 3L)
    1998 Black CSVT #1244 "pwntbywombat"
    Torsen T-2
    B&M Short Throw, K&N 3550
    Feb 2002
    Florida
    1,679
    On the door panel there's a handle that you use to close the door. Did you pop the plastic cover off of it? If I remeber correctly, there's 2 screws behind the cover.
    Vinny 2000 T-RED CSVT
    MODS: 18" REV model 2 ST200 struts/Roush springs
    CTA intake Pipe/K&N Filter
    Dtec Heatshield
    Optimized TB
    True Duals w/ magnaflow mufflers/resonators
    do you just wedge a screwdriver behind the panel (screw cover??) on the door handle and pop it out to reveal the screws?...
    i thought about that and tried a little but i couldn't get it to budge.....(i didn't try that hard)...any tips would be great because i need to finish this up tonight....
    Torsen T-2
    Quote Originally Posted by seabass_00svt View Post
    Yup, and once a corner of the handle comes free, pull hard to release the rest. Don't worry, they are strong.
    1998 SVT Contour (B/MNB) #542 3L
    2000 SVT Contour (SF/MNB) #1533
    2003 BMW 540i M-Sport (6 spd)
    2002 Lexus IS300 SOLD!!
    Also, I believe there is a screw behind the door latch (the little black thing you pull to open the door). there is a little round plastic cover you have to pop out with a tiny screw driver first, then the screw is behind that. Good luck
    99 T-green svt
    K&N & heatshield
    Opt. y-pipe
    Borla
    Superchip
    DMD
    Magnecore wires
    Metal impeller water pump
    BAT / Bilstein kit
    21mm BAT bar w/ boxed subframe
    215/45/ZR17 Toyo Proxes FZ on Rage 5.0's
    jimmkreider@yahoo.com
    Nov 2004
    Greater Des Moines Area
    1,356
    If at all possible use a popsicle stick or something to pop the cover off of the door handle...a screwdriver can damage the plastic. If it still won't come off tug on the door panel all the way around and try to see where a screw might still be hiding.
    Jul 2003
    university of toledo
    720
    Don't forget, you have to remove the little triangle part where the door meets the dashboard, you also have to take out the part where the door handle is too then feel under the door and make sure you got all the screws out of there as well. The panel should lift straight up.
    56 DeSoto (Viper powered) - under construction
    http://www.cardomain.com/ride/3810932
    99 Contour Sport V6 116k - mad deebeez yo
    http://www.cardomain.com/ride/2527087/1
    Jul 2004
    Minneapolis, MN
    512
    Ya check the way bottom of the panel for screws and the sides. I recall to pop the Panel off, its Up and Off, not just gorilla it straight off. Im sure youre gonna love the upgrade. Post results!
    1998 Contour Svt Born 5/12/97 #897 of 6535 or 2487
    (depends how you look at it)
  9. #9
    thanks guys....i got them off...got the speakers installed and put them back on...its perfect...
    Torsen T-2
  10. #10
    one more question.....how close are the tolerances btw the window and the back of the speaker?...because the infinity speakers i put in had a hell of a lot bigger magnet than the stockers that were in there and on one of the doors the speaker harness wedged btw the magnet and the window and jammed the window...
    i took the panel back off and taped the harness off to the side and the problem was fixed but that says to me than the clearance btw the window and the speaker magnet is like 1/8" or 3/16"....anybody else have this prob??
    Torsen T-2
