Results 1 to 6 of 6
Thread: Clutch Slave Cylinder Hydraulic Line Replacement?
    Aug 2009
    Scarborough, ME
    28
    Default Clutch Slave Cylinder Hydraulic Line Replacement?
    I'm wondering how I can get ahold of a replacement clutch slave cylinder hydraulic line (that's all the shop manual says it is.) Is there a place online that's good for it, or is the dealer the best bet? I'm asking now because the parts department closes at 4pm here, so if I could order it online, that'd be sweet.
    Oct 2004
    Northern MN
    8,245
    Check rockauto.com
    2011 Fusion SE V6 & 07 Honda Pilot EX-L
    98 3.0L SVT Sold 9-11-11
    99 3.0L SVT Silver Frost #1264 Sold 1-22-10
    95 SE MTX---Sold 9/14/07 sniff
    98 E1 SVT #4892 of 6535T-Red Sold 8-29-08
    Sep 2002
    Fox Lake, WI
    14,998
    *CLICK HERE ---> 1995 SE 3L WITH MATCHING TRAILER <--- CLICK HERE*
    25 Contour / Mystiques and counting......
    I'M POWDER COATING AGAIN! PM ME FOR REQUESTS.
    Aug 2009
    Scarborough, ME
    28
    Quote Originally Posted by blu_fuz View Post
    That's the ticket!
    And thanks for the rockauto suggestion! Should be here soon.
    Aug 2009
    Scarborough, ME
    28
    The shipping estimate lied and the part just came in today.
    I went outside to take the old one off, took the clip off, but it wouldn't budge. Its rusted or something onto the male end coming from the slave cylinder. I put a pair of vice grips on it, and romped on it, that didn't work either. I tried using a screwdriver to pry it off, broke the tip off of 3 of them by trying as such.
    Is there some kind of method to get this off? In the book it just says "remove retaining clip and pull out hydraulic line."
    Also, the one that's on the car now, the female piece that goes onto the slave cylinder line, its metal, the replacement one is plastic, I'm guessing that's just an improvement they made at some point over stock design.
    Sep 2002
    Fox Lake, WI
    14,998
    I had problems like that:
    I got the damn thing out. Crazy! I think this was the most troublesum part on the entire build. Took the most time in the beginning, so I cut it and then another 3 hrs to finally get it apart....
    Quote Originally Posted by todras View Post
    Never seen anything like that at all. Never had an issue with that in the least.
    Quote Originally Posted by ctmystique View Post
    Glad you got it seperated. Those are some nasty pictures.
    Did you have to resort to heat?
    Didn't go to heat for help. PB blasted it again 2 nights ago and let it sit. Hit it again with a wrench and it barely started to spin but not pull out. I used a flat head screwdriver and a hammer to pry it out from the hard line........
Similar Threads
  1. How do I remove the clutch hydraulic line
    By KyleH in forum Duratec Performance
    Last Post: 11-15-2008, 10:38 PM
  2. 96 SE bleeding clutch master cylinder
    By unior in forum General Troubleshooting
    Last Post: 11-27-2007, 06:29 PM
  3. Dead Clutch Master Cylender
    By rkneeshaw in forum General Troubleshooting
    Last Post: 08-27-2007, 09:39 PM
  4. Help - need clutch line clip
    By ven0m in forum Transaxle
    Last Post: 07-12-2007, 02:08 PM
  5. Removing Clutch Hydraulic Line
    By Mr.T in forum Transaxle
    Last Post: 03-14-2007, 10:55 PM
