Page 2 of 2
FirstFirst 1 2
Results 11 to 19 of 19
Thread: How-to: Short Shifter Install
  1. #11
    May 2004
    Calgary, Alberta, Canada
    4,437
    Quote Originally Posted by hotdimmes View Post
    I never adjusted anything after my steeda install. Could that be why my shifting feels notchy?
    mine feels notchy too, i like that.. Except my 2nd and 4th are stupoid short and Reverse.. Lets say its HARD to get it into.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
  2. #12
    Feb 2006
    Southeast Michigan
    2,368
    Explain with a little more detail what you mean...
    I have the Steeda short throw and it didn't need to be adjusted.
    98.5 T Red SVT #4636/6535 ... SVT cam'd 3L Turbo
    Owned 28 SVT's, looking for my 29th. Need SVT Parts? PM me!
    PM me for engine/trans/suspension swaps, etc... 3 Liter Swaps done RIGHT!
  3. #13
    Feb 2003
    Phoenix, AZ
    2,196
    Quote Originally Posted by Tourige View Post
    Sounds like your cable ends are gone and/or need to be adjusted.
    morbid
    2011 Edge SEL AWD (black) - daily driver
    2000 Contour SVT (black); #61 (Sept 17, 1999)
    3L with ADC turbo kit; 325hp / 338tq @ 7psi
    car is down with a broken tranny
  4. #14
    Dec 2003
    Newington, CT
    2,956
    It's notchy in the sense that the amount of force required to put it into gear is more than it should be. This is most prevalent for 2nd and Reverse though. It's not the peanut butter shifting experience, but more like they pop into place.
    Chris
    1998.5 Black Ford Contour SE 2.5 V6 MTX
    1988 Rosso Red Merkur XR4Ti 2.3T I4 T5 MT
    1982 Candy Flare Blue Honda CB650SC Nighthawk
  5. #15
    Dec 2004
    Utah
    1,124
    I just noticed that I dropped the washer without knowing it, finding it later in the carpet. Can anyone tell me where to put the washer?
    "Next to the dryer" is not the answer I'm looking for.
    Black 1998.5 LX
    3.0L Split Port Conversion
    HMS Transmission
    Lots of other stuff
    Ressurected 06/14/06
  6. #16
    May 2006
    Glen Ellyn, IL
    2,550
    Quote Originally Posted by muntus View Post
    behind the c-clip
    -Jon
    99 SVT Contour T-Red. #2437
    www.myspace.com/ripscottfrost
  7. #17
    Dec 2004
    Utah
    1,124
    Thanks x10.
    Black 1998.5 LX
    HMS Transmission
    Lots of other stuff
  8. #18
    Feb 2007
    Kansas City, MO
    75
    Thanks for the good write-up.
  9. #19
    Default 2000 csvt cfm short throw shifter installing
    while i was doing research on how to install my cfm shifter into my 2000 csvt, i cam across a hand full of threads that contained detailed info regarding this install.
    1. csvt#49's thread
    2. kingppinsvt's thread
    3. striker2's cfm install thread
    however, none that i found was specific to the 2000 csvt. afaik, the 2000 sts install required the riser plate. i bought the cfm shifter complete with riser place, new bolts and even 2 allen keys and a torx bit! kudos to the cfm team for offering such a thoughtful and complete kit!
    when i took apart my center console, i was kinda unsure exactly what i was looking at because the shifter tower before me does not look like those i have seen on those previous sts installation threads... i did some more researching and found this on the NECO. then it became clear that my 2000 csvt came equipped with the updated focus shifter tower that does not require the use of the riser plate! which sorta contradicts what i've learned up to that point... regardless, i was pleased at the find non the less.
    i would like to point out that dislocating the bottom cable is easier than using a flat head to pop it out. simple press the center of the cup like a button and the ball will pop right out! lastly there are much debate on whether the shifter cables will need to be adjusted. i was thinking that a "how to" adjust the cable link would have been a great final touch should you decide to perform the adjustment. The procedure is in this thread under striker2 and brapple's posts.
    over all, the shifts for my car feels much more solid and much less play. you can definitely tell the shifts are shorter as i need to get used to this new decreased shift length. construction of the cfm kit is top notch and thoughtful. i do kinda miss the reverse lock out feature of the old shifter... the reverse lock out gave the car a "euro" feel.
Page 2 of 2
FirstFirst 1 2
