Page 11 of 189
FirstFirst ... 9 10 11 12 13 21 61 111 ... LastLast
Results 101 to 110 of 1882
Thread: #49's new powerplant has arrived, let the build begin
  1. #101
    Nov 2000
    Fridley, MN, USA
    2,396
    I just noticed your tips in that picture above look like an Audi symbol. Maybe it's because I recently picked up a S4 though. lol
    Good luck on the build.
    Visit: 3LDuratec.com for a prepped 3L ready to drop in!
  2. #102
    May 2004
    Coon Rapids, MN
    5,317
    Quote Originally Posted by Blackcoog View Post
    Thanks Chris. I think with your recent purchase your on the look out for anything Audi You must not even look at a package of donuts in the same way... kinda like Homer Simpson.... mmmmm Audi
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
  3. #103
    May 2004
    Coon Rapids, MN
    5,317
    Default Pics and more pics...
    Tear down from last night...
    more to come 10 pic limit
    -Mike
  4. #104
    May 2004
    Coon Rapids, MN
    5,317
    That wraps it up for last night... I'll be posting pics from today in a moment
    -Mike
  5. #105
    May 2004
    Coon Rapids, MN
    5,317
    Default Engine Parts Update
    K1 rods are now ordered. Pistons will be purchased through CP Pistons-Carrillo through Wagamon Bros. Will finalize those details sometime early next week. Most likely will be honing out the bore by 0.5mm to clean things up for the new pistons.
    -Mike
  6. #106
    May 2004
    Coon Rapids, MN
    5,317
    Default Completed Teardown
    This morning I took the rest of the engine apart.
    Oh yea and to keep my bolts in order for the oil pan and block I made this...
    -Mike
  7. #107
    May 2004
    Coon Rapids, MN
    5,317
    Cool ST220 is back from Extrude Hone
    UPS driver number 1 dropped this off...
    -Mike
  8. #108
    May 2004
    Coon Rapids, MN
    5,317
    and then UPS driver number 2...
    -Mike
  9. #109
    Jul 2004
    Michigan
    5,868
    That UIM is fuggen clean ...oh it looks dead sexy
    Do the ports look bigger? have you taken measurements before and after?
  10. #110
    Jun 2006
    Center City, MN
    2,888
    that clutch doesnt have the larger rivets or completely closed windows. what have i been telling you guys about the clutchnet discs for the last year or longer? the outer disc can be disconnected from the hub just as easy as a spec with those..... less likely to fail than a spec, but still likely.
    mike your block looks pretty good i hope it turns out well. has anyone else noticed that his crank has WAY less machining done to it? the 2.5L crank i have from my SVT motor is completely machined on every side of the counterweights (porkchops, if you prefer the simple terms) i assume this would be considered "knife edging" which the 3L crank is not. are all 3L cranks this way?
    R.I.P. CSVT "clockwork" totaled 10/29/10 n/a 3L 220whp 212 trq
Page 11 of 189
