radioactiveman
Hello, Should the range sensor on a 98 2.5 auto just slide off from that middle shaft or is there a guide or anything like that where it has to be taken off at the right degree? also there is a rubber hose that comes off the tranny must be a breathing tube right next to the sensor twards the driver side fender, does that connect to anything or is it just an open end breather or does it need to be conected to some sort of vaccum? im in the process of removing that range sensor now.
