+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: AEM Wideband
  1. #1
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default AEM Wideband
    Just have a question about these wideband sensor/guages.
    ive searched and found out our stock O2's are only narrow band. I want to pick up a Wideband AEm guage kit but i first would like to know how it works.
    Narrow band only reads lean or rich (14.7:1 being at idle) but under load we all know it dosent stay there while in OPEN LOOP.
    Would this Wideband take place of the factory O2 or would i need to drill a hole somewhere in the exhaust, weld a nut, then install the sensor there?
    i couldnt find a write up on installing one. But i Definatly will once i decide to get one.
    98.5 Black/Midnight Blue SVT-Build # 6122 - Resonator Replaced with GlassPack - NPG CAI - MSDS Headers - TruBendz y-pipe - Port-matched 3L with SVT cams.
  2. #2
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default
    Found my answers on the SRT4 Forums! And just ordered the Gauge. I will be doing a write upon installation! but for those who need some info now and want to know how it works:
    http://www.srtforums.com/forums/f75/...deband-210014/
  3. #3
    Join Date
    Mar 2004
    Louisivlle Ky
    Posts
    6,934
    Default
    Quote Originally Posted by 1BadJag View Post
    I installed mine in my y-pipe when i optimized it. just welded the bung in while i was welding the whole closed.
    TZT Performance http://www.tztperformance.com/
    officially a troll. '93 3000GT VR4 #2229/2595
    '00 Black SVTC #391 - sold 5/1/10
    '97 GL Turbo Zetec - gone
  4. #4
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default
    Thats what im doing! Optimizing y-pipe and throwing the wideband in. Come spring time ill be throwing in our new motor/trans with a paxton sn93 setup. But i wanna do all the little things in the mean time.
  5. #5
    Join Date
    Oct 2006
    Up North New Jersey
    Posts
    1,801
    Default
    My wideband is installed after my downpipe closer to the exhaust. Drilled a hole from under added a grommet and it fit perfect where I mounted it!
    - amyn
    '99 (Mystichrome Bay, No Powertrain, No Trunk) CSVT - 0532
    Koni/GC's - 18" KR206 - BAT 21mm RSB(Reinforced) - OMP/Rawburt - WPN R Headers to Bassani Catback - Ford Racing Wires - CF Trunk,Hood&Lip - Parkedcar Stamped - Samco Hosed - Baer BBK - 3L Turbo
  6. #6
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default
    For the wideband "power wire" could i use the remote on wire from the radio?
  7. #7
    Join Date
    Dec 2001
    Gales Ferry, CT
    Posts
    24,478
    Blog Entries
    93
    Default
    you could but what if for some reason you don't turn the radio on?
    just tap the ignition.
    - 12 Focus SE
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport <- trading in 2/11
    - 99 Contour SeVT <- 3L/NPG Turbo
    - 2k Contour SVT - #2137
  8. #8
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default
    Would u like to assist me with that? Where should i tap it in at? And how. Sorry if it was a dumb question.
  9. #9
    Join Date
    May 2006
    Plymouth,MI
    Posts
    3,054
    Default
    Quote Originally Posted by BrApple View Post
    No. That breaks stuff.
    Tap Cig lighter.
    '98 SVT E0 BLK/MNB#1663 Port matched 3L
    '99 SVT E1 BLK/TAN#0741
  10. #10
    Join Date
    Jan 2009
    Fredericksburg, VA
    Posts
    71
    Default
    splice into the hot wire coming from the fuse box to the cig lighter correct?
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Wideband Location Question for the Experts
    By NothernMystique in forum PCM Tuning
    Last Post: 01-06-2008, 10:11 PM
  2. AEM wideband connected to Xcal2
    By SHOgoFast in forum PCM Tuning
    Last Post: 10-08-2006, 01:35 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
