Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: p0442 code
    Default p0442 code
    i had a check engine light when i was driving home yesterday. i had the code read and it said it was a small emission leak so i heard it might be my gas cap which i think it was cause when i loosened it i did hear the pressure released. also i remembered when i last gassed up sunday i smelt a wiff of gas in my car after fueling it. it was strong too. so im looking on getting one from autozone on payday. anyways what fuse i pull out to reset the cel light? thanks
    1995 Contour GL Zetec with 116k miles.
    1999 Ford Contour SE Zetec with 145k miles.
    AIM Name: ContourAlf
    Yahoo IM: Contour_Freak
    WANTED...
    7 spoke SE rim center caps for a 95. PM me if you got one.
    Jun 2005
    Virginia, USA
    11,070
    To reset the PCM, and clear the Check Engine Light, pull fuses 4 and 11 in the Power Distribution Box next to the battery.
    Para espanol,
    quite y reinstálese fusibles cuatro y once en la caja de distribución de energía al lado de la batería
    How do like them apples?
    "Entiendo un poco español"
    or just unhook the battery and pump the brakes 3 times.
    98' Contour SVT #2037- 132k, (blk/mnb) 04' 3L ported w/ SVT cams
    Chevrolet Blazer- 111k, mostly stock
    Sep 2002
    St. Louis, MO
    2,633
    Quote Originally Posted by pre98zetec View Post
    yeah, but then you have to reprogram your radio... and that's after finding the tools, etc...
    Just pull the PCM KAM fuse only, the other one isn't needed.
    Steve
    98 Contour SE Sport 2.5 Duratec ATX Was the wifey's car, now it's mine - 170K
    89 Taurus SHO - Retired at 249K miles
    94 SHO ATX - 240K
    1997 F-150 5.4L E4OD - The Workhorse 170K.
    2007 Mariner AWD - Wifey's new ride.
    Jun 2004
    Kitchener, ON Canada
    1,996
    Quote Originally Posted by Tony2005 View Post
    Para espanol,
    lol what are ya doing tony? takin spanish lessons?
    95 Mystique 2L Auto
    98 SE Contour Auto
    98 Taurus Vulcan Auto
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by loggerbomb View Post
    LOL. Si Senor. Soy estudio espanol en escuela (con Consuela. La Senorita es hermoso).
    Para Ingles presione uno.
    Yes, Sir. I'm studying Spanish in school (with Consuela. The young lady is beautiful).
  7. Default
    OK, this has happened to my niece twice now in the last 2 months. Same code (P0442). The manual that came with my code reader says it means "Evaporative Emissions Leak (Small)".
    I just cleared it again yesterday, and told her if it comes back for a 3rd time we should try a new gas cap. If that doesn't do it, does anyone have any other suggestions? TIA
    '99 'Tour (actually my brother-in-law's, but I'm the family wrench...and now he's given it to my niece who's putting 600 miles a week on it commuting to college!)
    Mar 2004
    Louisivlle Ky
    5,153
    Make sure that when you close the gas cap that it clicks at least 3 times. if your still getting this code and you are closing the cap fully then i would try a new gas cap.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
  9. #9
    Jun 2005
    Virginia, USA
    11,070
    Quote Originally Posted by RF Overlord View Post
    Try cleaning the seals first and then try putting a little vaseline on the seals before getting a new gas cap.
  10. #10
    Also check the solenoid on the charcoal canister for proper operation. This too is a known problem.
    Russ
    2002 Ford Ranger 2.3
    2003 Buick Regal GS
    1998 Contour Sport
    2003 Saturn VUE
