this is where i agree with you. if he is going to get a mail order tune, from say NPG, then just stick with the 19s since it has been done so many times. yes, your pushing the limits of them but it seems to be easier to get the car running right with them on a mail order tune. If he is going to get a dyno tune some place then go with the 24s as they will be able to better see whats going on with the car since its in front of them.
here is some more info I found.
according to these 2 sites
http://www.fuelinjector.citymaker.co...INJECTORS.html
http://users.erols.com/srweiss/tableifc.htm
from the first site, the 98 SVTC uses a Bosch 0-280-155-710 fuel injector. looking that part number up on the second site reveals its only rated at 18.25lbs/hr flow at 43.5PSI. with a BSFC of .52 at 95% duty cycle, each one is good for ~33.3 HP, times 6 gets you to 199.8HP.
the 96-98 duratec Taurus uses a Bosch 0-280-155-715 injector. they are rated at 22.45lbs/hr at 43.5PSI. with the same .52 BSFC and 95% duty cycle, each one is good for about 41HP, times 6 is 246HP.
while i cant seem to verify the injectors used in the later oval port 3Ls, i suspect they are Bosch 0-280-158-075 which are rated at 24lbs/hr at 43.5PSI. these are good for about 43.8HP, times 6 is 262.8.
Also, apparantely the 98 SEs are listed as having Bosch 0-280-155-725 injectors. those are listed as ALSO being rated at 18.25lbs/hr at 43.5PSI
obviously, depending on your exact BSFC depends on how much HP you can get out of each injector at a given flow rate. a more effecient engine with a lower BSFC will be able to make more power on each injector.
