Results 1 to 3 of 3
Thread: Just curious
  1. Default Just curious
    Not that Im planning this, but I was wondering if anyone had considered swapping in the new 3.5l from the MKZ? I think they are 262hp stock and probably have decent torque numbers too. Is it the same block as the standard 3L?
    May 2000
    Grand Rapids, MI
    26,864
    Blog Entries
    1
    Yep. Put one in last week. Completely redid the entire engine harness and PCM so that the VVT & coil on plug could work. Refab'd the subframe and firewall too. Car really rips.
    Feb 2004
    Somewhere in MO. Bleeding Mercon 5
    1,082
    Todras Says:
    Actually it has been discussed. It will take a lot (A LOT) of work. Currently the bellhousing I understand is different, which would need to be addressed to add the MTX-75, as well as having a way to control the VVT. This part can be controlled by an aftermarket Engine Management System with the proper tuning. We are also not sure if the motor mounts will work without completely redesigning the engine compartment. Subframe would have to be addressed at that time as well. Not saying it can't be done, just takes money and time that most of us don't have to tackle a project of that caliber.
    Mazda North America Sales (K.C. Mo.)
    Buy Mazdas From me!!! Think: MazdaSpeed
    E0 3l--13's **Parting Out**
    2000 SEVT-- The Pretty Car (Work in further Progress)
