Page 1 of 2
1 2 LastLast
Results 1 to 10 of 12
Thread: walmart platinum burner install how-to and walkthrough
    May 2009
    Cape Cod, MA
    897
    Default walmart platinum burner install how-to and walkthrough
    Step 1: Removing the weather shield. Remove weather shield from bottom of car by removing the 9 torx screws and washers, and then pulling off. 5 are under the car, and there are 2 in each wheel well.
    Step 2: Removing the factory fog lamps and mounting assembly. Refer to picture to see whole unit to get an idea of where the screws are. With the weather shield removed, you should be able to see both fog lamps from under the car clearly. Start by disconnecting the plugs(I prefer to do one lamp at a time, start to finish, then start the next one, but that's just me). Next, remove the two push pins on the bottom half of the mounting unit. With those off, the only thing left securing the top half, which holds the lamp itself, is the top screw. Remove this by using either a philips head screw driver of a 7/32 socket. I prefer the socket. with the screw out, the top half can be pulled free. Using the same screwdriver/socket, you can remove the bottom half of the mount by removing the lower screw. Note: these screws can be quite stubborn with rust from 9+ years of driving in different sorts of weather. I had to use wd-40 on both lower screws.
    Step 3: Removing factory lamps from the factory mounting assembly. Remove the alignment screw and spring. Bend one side of the mount outwards while pulling the fog in the other direction. The peg securing it should come free(see pic) and the lamp should be out.
    Step 4: Placing new fog lamps in factory mounts. Remove all hardware for the new mounts from the lamps, as you will not be using them. Save the two black nuts, as you will need this. Using 2" screws with the correct threads for the black nuts, pass them through the holes in the factory mount where the pegs had previously gone. Secure to new fog lamp by threading into the two nuts. For this to be a proper fit, I used 7 washers and a nut on each side. This allows the lamp to swivel. To secure, you must use a nut on the inside of the mount, and tighten that to the mount. See pics.
    Step 5: Modifying your wiring. I did not want to touch the stock wiring, in case I ever wanted to go back to the factory look. What I did was modify the factory bulbs instead. Remove the bulb part of the bulb, leaving the leads. Sand this leads using low grit sand paper to ensure a good connection, and connect the wires for the new lamps to those using heat shrink tubing. Insulate with electrical tape.
    Andrew
    T-red/MNB "The Wizard" 1998.5 CSVT #5314 128,000mi
    any installed pics yet? I may do the same thing with my foglights after i get the bumper repaired. My only concern/question is, do the new fogs sit flush with the "hole" in the bmper, or is there a gap?
    2011 Kawasaki Ninja ZX-6R: GP-style shifting, and more mods to come.
    1998 Black CSVT #4754: '03 ported 3L, Opt'd SVT TB, NPG CAI, Torsen T2, MSDS headers/y pipe, Trubendz Testpipe, Magnaflow.
    2005 Redline CTS-V: 400hp of awesomeness on the weekends
    Jul 2008
    st.Louis ,MO
    187
    that was something i did when i first got my car, thought i was the only special one
    -nice write up-
    1998.5 T-red SVT #4689
    00' silfro *wrecked*
    99' black se sport
    00' t-red se *sold 4-25-06
    Apr 2008
    Sussex, WI (Illinois is beneath us)
    842
    To weatherproof the bulb socket wires, Hot glue inside of heat shrink tubing works great. That will work better on keeping the moisture out than that electrical tape. Nice write up though.
    '99 CSVT #1194 -'04 3L
    '05 Subaru Legacy 2.5 GT Limited
    Ive never seen anybody utilize a fog light bulb like that to make their own wiring harness, kudos for your creativity.
    got pics of installed? I did my proburners a different way.
    Sold the CSVT, replaced it with a Screaming Yellow 2003 EAP SVT Focus
    Jul 2004
    Michigan
    5,868
    Quote Originally Posted by AliasJerk View Post
    Actually i did mine the same way he did his (the wiring). I hate hacking things up if it doesn't need to be.
    Nov 2008
    Eau Claire, WI
    134
    Anyone else have a problem of the lights aiming way to high. Just installed one side tonight and they're as bad as the high beams.
    '98 Mystique LS ATX V6 165,000 miles-sold 3/2/10
    ...and the recent acquisition
    '97 Contour SE MTX V6 97,000 miles
    I did the same thing to my Mystique using Pilot fog lights that I got at Autozone for $20. Good write-up!
    1999 Mercury Mystique
    K&N short ram
    Sparco Pista 17" wheels
    Continental DSW's
    HID conversion
  9. #9
    Oct 2005
    Toledo
    1,186
    anyone else crack these lights all the time?
    i've turned replacing these into an art.. I can replace both, solder the new wires and have them reinstalled in 45 minutes
    I usually get a new set every year
    TRed CSVT on FSVTs (previous car)
    http://www.cardomain.com/ride/2154233
    Black CSVT on FSVTs (current car)
    http://www.cardomain.com/ride/3933448/
  10. #10
    Jul 2011
    cedar rapids, ia
    204
    Great write up! Very easy and cheap mod. It looks awesome and makes a big but subtle difference.
    1994 Ford Probe GT- bone stock 87k mi. future ATX-MTX
    1998 Contour SVT #393- WRSW intake, custom heat shield, platinum burners, d/s rotors, tzt toe arms, poly bushings
    1995 Probe GT- klze, intake, short throw. *SOLD*
Page 1 of 2
1 2 LastLast
