Page 1 of 4
1 2 3 ... LastLast
Results 1 to 10 of 38
Thread: Nitrous Kit Questions
    Default Nitrous Kit Questions
    I tried searching already, and it seems that there are over a million different opinions on this subject... but here is what I have:
    1998 SVT Contour 2.5, basically stock
    Weapon-R Cold Air Box
    Weapon R Secret Weapon Intake
    ProFlow MAF Calibrater
    Magnacore Plug Wires
    BAT Y-Pipe
    Bosal Cat Back System
    Soon to get: Fidanza Flywheel, Spec Stage 2 clutch, and driveline shop stage 2 axles
    and a nitrous system
    Problem, what nitrous system to go with, and what software, programming will I need to do to get the most bang for my hard earned buck?
    I see a few people that have went with zex, which I am ok with, but want to ensure as few problems as possible, and am kind of ignorant to the whole thing...any help will be much appreciated.
    Aug 2003
    DFW (Keller, TX)
    2,487
    you'll need an LSD over the axles
    98 SVT # 692 05/02/97 3L turbo....SOLD!!!
    DD: 2005 Honda Civic 39.7mpg (best so far)
    Wife's car: E53 X5
    garage: E39 M5
    Jun 2006
    Center City, MN
    2,796
    agreed. i'd get a LSD, however i have run a 100 shot on my stock axles and diff, the only thing that went was the stock clutch. i went with a stage3. you dont want a spec stage2 clutch, its got kevlar in it (slippage!) get the stage 3, 6puck design. its about the same price anyhow.
    as for the nitrous kit, that's all based on opinion. i'm a NX guy myself, and i definately would go with a wet kit, unless you plan on upgrading your fuel system quite a bit. i also recommend a window switch, WOT switch, and a fuel press. safety switch. if you have more questions go ahead and pm me i can give you all i know about it, i have run 32 bottles through my car and its got 147k on it now, on the original engine.
    98 CSVT-black. on it's second 3L swap. 219hp/211 trq
    Aug 2003
    DFW (Keller, TX)
    2,487
    Quote Originally Posted by TRicker View Post
    I would say that's pretty lucky becasue many (including myself) have blown diffs stock!!!!
    Just as a side note...I had a stage 2 fr a while and I never had probs with it...although I may have lucked out on that as well.
    Wife's car: E53 X5
    garage: E39 M5
    Jun 2006
    Center City, MN
    2,796
    yeah i have no idea how i havent blown it. maybe i'm lucky, or maybe the person before me already blew one and put in a LSD? i have no idea
    Waste of money
    Waste of money
    Waste of money
    Good quality
    Decent copy in mild steel
    Waste of money
    Oh, that wasn't your question.
    Any wet kit is a good option. A 75 shot is a safe range to run. Make sure to run 92 octane or better, the higher the better of course.
    2000 SVT #674
    13.47 @ 102 - All Motor!
    2005 Magnum R/T
    2 Ton Tank with a Hemi
    May 2004
    Calgary, Alberta, Canada
    4,506
    Why do you need a WOT and a window switch?
    Just get a WOT system. The zex system is good and easy to install, its clean and dosent take up much space.
    Tricker will swear By NX as do a lot of people, their solenoids are very good, some people dont want to deal with the amount of wires and garbage that is associated with the NX kits tho.
    Im running a 75 shot, bottle heater, purge kit, wideband, Custom tune with Flip chip by Lightspeed Innovation. I'm on the stock diff and clutch, my tranny was rebuilt by ford about a year and a half ago tho, plus i only use the Nitrous >4500RPMS in 2nd.
    Wet kit is definatly the way to go if you have the choice.
    If you go with the Zex kit, go Wet, get a bottle warmer, a purge kit, a nitrous pressure gauge, a blowdown tube, Wideband 02 sensor, use the WOT setup from zex, get a custom tune, and run a Fuel pressure safety switch just for extra insurance.
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
    Jun 2006
    Center City, MN
    2,796
    tourige i just like the window switch for added security myself...my foot gets heavy when im racing...your right though, both are not necessary
  9. #9
    May 2004
    4,506
    as long as you dont power shift like a madman you should be fine.
    Window systems are probably the better way to go tho, it lets you launch without having to worry about massive wheel spin.
    WOT switches are better for roll racing and just general fun, nothing beats sitting at 5000rpms next to your buddy, flipping a switch, mashing the pedal to the floor and flying away.. Man i miss summer..
    230.2 WHP @ 6500
    237.0 WTR @ 2250
    99 Tropic Green SVT
  10. Default
    Well I think you could still do that with a window switch, which is really what Id like to set up for my system. The WOT switch would be the primary way to activate, but it would not work unless a window switch was completing the circuit.
    That way, you get the 'on now' feature of WOT assuming that you're in the right RPM range. (Say 3500 - 6500).
    I figure this way will work the best for me because I often like to let the revs ride out at less than full throttle, (which would activate nitrous if in the RPM range with only a window). I also have the saftey of not having to worry about WOT slips or anything.... Ask mark about my highway downshifts
    If im off base on anything, I hope you guys can chime in and correct me!
    US23
