Page 1 of 2
1 2 LastLast
Results 1 to 10 of 14
Thread: Alternator R&R Duratec
    May 2004
    Coon Rapids, MN
    5,291
    phew. Well all work was not done in vain. Took the alternator from the car up to the O'Reillys and it did fail on their bench. Just finished installing the alternator I had sitting around and boda bing boda boom 13.9V, winner!
    Oh by the way the alternator replacement how-to is no longer available in the general maintenance forum FYI. All three bolts can be accessed from the bottom easily once you find the sweet spots with a 13mm socket for the two flange bolts, 10mm for the bracket bolt, universal joint, and two long extensions (5" I believe). I wish I would have taken some pictures, but ugh I just wanted this crap finished. I was sweaten big time there with CarCraft Summer Nationals coming up this Friday.
    Anyway thanks to all for the pointers guys, CEG rocks the house again. As it turns out my initial thought was correct. Just fricken weird that the alternator just went fubar while I had the car down for powder coating...
    EDIT: I went back and took a bunch of pictures of the new installation basically, but it shows the tools I used and where I put them to get the bolts out. I'll post up an updated How-To in the general maintenance forum so that people can see pictures since Ray's old How-To is lost with the rest of the archives. Stay tuned...
    -Mike
    98 SVT Contour - HoK TruBlue|CF roof|#49/6535 DOB 3/25/97|550whp here I come|Follow my extremely slow 3L/turbo build here Link
    85 Camaro - 1969 350ci, 503BHP
    05 Ford Expedition Eddie Bauer Edition - Every option
    May 2008
    Humble, TX
    323
    Found a .pdf copy of Ray's old how to post. Too late for CSVT#49 but might help others.
    _
    1999 Silver Frost CSVT born 04/07/1999, #1777 of 2760 (Sold 3/31/11); 1999 Spruce Green SE Sport 2.5L ATX daughter's car
    May 2004
    Coon Rapids, MN
    5,291
    Quote Originally Posted by Silver Bullet View Post
    _
    That's a good how-to, but it kinda lacks pictures of the bolt locations. Also there is no need to remove the coil pack and go in from the top. The top bolt on the alternator is easily accessible from the bottom as are the other two bolts. I'm going to submit my pictures and a small write up to the general maintenance how-to. However I'll post up the pictures here as well if someone searches here.
    -Mike
    May 2004
    Coon Rapids, MN
    5,291
    Here is a brief explanation through the use of photos of the removal of my alternator.
    Tools:
    15mm wrench (or 15mm deep well 6 point socket)
    3/8” universal
    3/8” 10mm 6 point socket
    3/8” 13mm 6 point socket
    3/8” ratchet
    3/8” breaker bar
    3/8” extentsions
    1 – 8”
    2 - 5”
    Torque wrench capable of 25, 28, 45 and 128Nm
    block of wood and hammer (or rubber mallet)
    Not shown is the removal of the wheel (reinstall lug nuts at 128Nm) and removal of the wheel well covers.
    Drop light placement to fully light alternator removal (EGR recirculation pipe)
    Bolts on lower portion of alternator
    Lower bolt extension placement (below steering rack hard line)
    Lower bolt with socket on it with above extension placement (lower bolt removal uses 13mm socket and should be reinstalled at 45Nm)
    Upper bolt extension placement (above steering rack hard line)
    Upper bolt with socket on it shot from wheel well (Upper bolt removal uses 13mm socket and should be reinstalled at 45Nm)
    Mid bolt extension placement and bolt (Mid bolt removal uses 10mm socket and should be reinstalled at 25Nm)
    Tie rod removed using 15mm wrench after cotter pin is removed (reinstall at 28Nm with new cotter pin). Note do not use a pickle fork as you will more then likely reck the boot. Take a block of wood, line it up with the stud of the tie rod end and hit it with a hammer (or use of rubber mallet) to pop the tie rod end out of the knuckle. This is required so that the alternator may be dropped down, tilted back and then pulled out through the opening created by the tie rod removal shown below.
    -Mike
    Thumbs up Alternator Info.
    Hi Guys. I am new to this. But I had to Thank all the fellows that take the time and share their experince with projects they have accomplished. We all know how stressful tackling a job can be without any guidance. I am going to tackle the alternator this weekend. Seems relatively easy. Thanks to info and pictures. You guys all are an asset to society.
    Dec 2005
    formerly las vegas, now dallas TX
    3,513
    On a side note: If any have a difficult time trying to get the small black metal bracket back on, its okay to run the car without it. I havnt had it on my turbo'd car for years now. No drawback whatsoever. If anyone sees a potential problem tho, pls post. And i'm talking about the metal piece in the upper part of CSVT49's 3rd picture with the circled bolt.
    Julian
    98.5 csvt #6226 of 6535
    Rally Inspired 3L turbo'd monsTOUR
    Modifications??? well...lets just say this ain'tcha grandma's contour
    Mar 2009
    Munster, IN
    179
    It's easy to keep that on though. don't take out the bolt that attaches it to whatever all the way. it'll move around a bit to give you enough play to get the alternator back in and then retighten that to the alternator. now changing the alternator is a pain though. I would NOT want to do this again.
    Jan 2006
    Chicago Area
    204
    I just completed this job on my SVT. It took about 2-1/4 hours to remove the alternator starting with driving it into my garage. I then took it to my local rebuilder who had one in stock and after walking out $132 dollars lighter I had my rebuilt alternator to install.
    One thing I read was some people had problems getting the alt. to fit back into the slots that hold the alt to the bracket that bolts to the engine. I can see this as I had to pry out my alt. as it was a tight fit in there. The 12 years and some corrosion will do that. What i did to make it MUCH easier to install the "new" alt. was to widen the slots on the bracket.
    To to this all you have to do is get a long drift, punch, or rod and a hammer. The bracket had two double lugs. One has a threaded hole that the bolt threads into and the other is just an oversize hole the bolt goes through first before it goes through the alt. mounting hole. This large hole has a steel split sleeve in it to prevent the bolt from deforming the aluminum when the bolt gets tightened. It is only a press fit so a few hard taps on the sleeve with the hammer and punch will force the sleeve out a bit leaving the slot where the alt. fits into a bit wider. When you tighten the bolts down the sleeve is forced back into positon and all is well.
    '00' SVT Contour
    '87' VW ITA 16V Scirocco race car
    "Drag racing is for those drivers who can't brake and downshift at the same time."
  9. #9
    Jul 2008
    Northern California
    155
    good tip, thanks jimbbski,
    and thanks to all who have contributed to this thread to make this daunting job a little more clear and a hell of lot less intimidating.
  10. #10
    Nov 2010
    904
    One problem, hit to hard and the bracket will break
    98.5 svt, going back to black, and a clean engine bay and nice wheels, anyone wanna buy it in the spring?
    LOCATION 55021
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Is the Duratec 30 a good engine?
    By GaryST220 in forum Duratec 3L
    Last Post: 03-17-2009, 10:44 AM
  2. Duratec Maintenance - Read First
    By GTO Pete in forum Duratec Maintenance
    Last Post: 03-21-2007, 08:46 PM
  3. Pulling 2.5L Duratec.
    By atlas in forum Eastern Canada
    Last Post: 01-16-2007, 03:31 PM
  4. Zetec vs Duratec 20
    By mcgarvey in forum Zetec Performance
    Last Post: 01-13-2007, 10:16 AM
  5. Duratec 35
    By CEM Rider in forum Duratec Performance
    Last Post: 11-03-2006, 11:10 PM
