Results 1 to 4 of 4
Thread: Alternator Rebuild kit?
    Default Alternator Rebuild kit?
    Has anyone found a kit and rebuilt there Zetec alternator?
    '00 'Tour Zetec
    South Jersey
    http://www.cardomain.com/ride/2679238
    Jul 2005
    South Jersey
    530
    PM'd you.
    You just need a alternator brushes, it takes a few minutes to swap them out. You can get them at most good autopart stores.
    Brushes are part of the regulator assembly on later 6G model alternator. Pulling apart alt requires also maybe buying the 'tolerance ring', a thin wall ring of plastic that takes up the space between rear bearing and the rear casting. The ring very often seizes up and destroys on rear case removal. Cheap part but hassle to find.
Similar Threads
  1. Forced Induction FAQ
    By beyondloadedSE in forum Forced Induction
    Last Post: 08-24-2009, 10:34 AM
  2. Non-intercooled kit
    By svtfan22 in forum Forced Induction
    Last Post: 04-02-2009, 09:33 AM
  3. Replies: 31
    Last Post: 12-25-2008, 05:11 PM
