ok sense the stock fsvt calipers/rotors bolt up. wont these brakes?
http://www.spmotorsports.com/ATCfocu..._kits_bat.html
there a twin piston caliper.
also im guessing you would need at least 17" rims
-JON 99 CSVT T-Red. #2437
www.myspace.com/ripscottfrost
Yeah, pretty much looks like it should bolt up. Also if you use the correct spacer offset.
Not a bad option and just a little more money than the straight FSVT conversion.
My project website
Negative, those will not work. They are designed for the non-SVT knuckle, which is quite different for caliper attachement than the SVT knuckle.
ok that makes sense. thanks
My project website
i can't wait for the big brake upgrade, big brakes look soooo nice
99 Blk SVT #2354/2760 Tints, MSDS headers WeaponR Y-Pipe, KKM intake, Pud Shield
REVIVED 3-23-08 at approx 3:30am by REEBS
R.I.P •••• Rob 1-3-89 1-15-07
