Results 1 to 7 of 7
Thread: FAQ: 3L Part Numbers
    Post FAQ: 3L Part Numbers
    Here are some of the part numbers for aftermarket and/or Ford OEM 3L parts.
    If anyone has any corrections or things to add to this post, please do so.
    Please keep other comments and/or questions in other threads please so that this post is just as informational as it can be.
    If you have part numbers, please post them here - 3L build related parts only.
    Note: Prices listed are what have been paid in the past and may not be current with today's pricing at your local parts store.
    Engine:
    Per Bill Jenkins:
    3.0L short block, NEW. Build date is from 04/01/03 and is the same part# for Sable, Taurus, Escape.
    4F1Z-6009-BA List $702.55 Inet $526.91 Core $500.00
    Seals and gaskets:
    - Fel-Pro Part# 61006 SE TB gasket, $1.59
    - Fel-Pro Part# 61006 SVT TB Gasket
    - Fel-Pro Part# 70149 EGR gasket
    - Fel-Pro Part# 9038PT 2.5L Left Hand Head Gasket
    - Fel-Pro Part# 9039PT 2.5L Right Hand Head Gasket
    - Fel-Pro Part# 9540PT 3L Left Hand Head Gasket
    - Fel-Pro Part# 9541PT 3L Right Hand Head Gasket
    - Fel-Pro Part# CS9038 2.5L lower conversion Kit (includes oil pan gasket, oil seals etc.), $72
    - Fel-Pro Part# ES72159 Head bolt set, 2.5L 2 req., $16.92ea
    - Fel-Pro Part# HS9038PT Head gasket set, conversional $231.15
    - Fel-Pro Part# MS92586 3L Plastic Oval Port Intake Manifold Set
    - Fel-Pro Part# MS95715 Exhaust Manifold Gasket (53mm x 32mm)
    - Fel-Pro Part# MS95726 Intake manifold gasket set, $30.15
    - Fel-Pro Part# OS30675R Oil pan set , $35.27
    - Fel-Pro Part# SS72873-1 Valve Stem Seals (Viton)
    - Fel-Pro Part# TCS45966 Camshaft rear seal gasket set, $6.95
    - Fel-Pro Part# TCS45967 Crankshaft front seal, $14.55
    (Includes 2.5L head gaskets that are not needed.)
    - Fel-Pro Part# VS50462 Valve cover set, $32.59
    - BCA part# 3909 Crankshaft oil seal, $13.32
    - BCA part# 5277 Crankshaft oil seal (teflon), $16.76
    - BCA part# 99363 Crankshaft oil seal (redi-sleeve), $33.50
    - BCA part# 88187 Harmonic balancer sleeve, $4.18
    - BCA part# 482041N Oil seal, front timing cover, $7.67
    - BCA part# 99187 Oil seal, front timing cover (redi-sleeve), $22.58
    - Spectra Premium #1719 non-SVT radiator, $138.41
    Clevite 77 bearings:
    - CB-1772P Rod bearing, available in standard, -.25MM, -.50MM, and -.75MM.
    - MS-2207 Mains (not yet available)
    Federal Mogul:
    - 7262M- Standard Grade Main bearings (also available in non standard grade)
    - 6-4395A- standard grade rod bearings (also available in non standard grade)
    Ford part numbers:
    - 2S7Z-6513-AA ST220 Valve Springs (measured 161-163 lb/in)
    - 3F1Z-6564-AA New Roller Finger Followers
    - 3M4Z-6675-BA Upgraded Oil Pan Set
    (2 drain back channels and better lower baffles – comes with gasket and hardware)
    - 4F1Z-6065-AA Head Bolts
    - F3LY-6214-A Connecting Rod Bolts, need 12
    - F5AZ-6700-A 3.0 Front Crankshaft Seal
    - F5AZ-6701-A 3.0 Rear Crankshaft Seal
    - F5DZ-9E936-AE SVT TB Gasket
    - F5RZ-2A411-A 2.5L UIM Plastic Retainer Grommet with Brass Insert Sleeve
    - F5RZ-2L181-AA 2.5L UIM Plastic Retainer Grommet
    - F5RZ-6020-A 2.5 Right Front Timing Cover Gasket
    - F5RZ-6020-B 2.5 Center Front Timing Cover Gasket
    - F5RZ-6020-C 2.5 Left Front Timing Cover Gasket
    - F5RZ-6345-C Lower cylinder block retaining bolts, need 4
    - F5RZ-6345-D need 8
    - F5RZ-6345-E need 5
    - F5RZ-6584-B 2.5 Right Valve Cover Gasket
    - F5RZ-6584-C 2.5 Left Valve Cover Gasket
    - F5RZ-9439-B 2.5 Lower Intake Manifold Gasket
    - F5RZ-9H486-BA 2.5 Upper Intake Manifold Gasket
    - F5RZ-17285-AA MTX-75 Speedo Gear
    - F6DZ-6345-CA need 5
    - F6DZ6505A Valve-exhaust
    - F6DZ6507A Valve-intake
    - F6RZ-9K313-BC Fuel vapor hose
    - F7RZ-4211-AC Differential Bearings (2 req)
    - W701-512-S301 TTY Crank Pulley Bolt
    - XF1Z-6051-BA 3.0 Right Head Gasket
    - XF1Z-6051-DA 3.0 Left Head Gasket
    - XS4Z-7201-CD Upgraded Shifter Tower (03+)
    - XS8Z-7230-DD 1-2 Shifter Fork, Roller Bearings (02+)
    - XW4Z-9448-AA Duratec Exhaust Manifold Gasket (50mm x 26mm)
    - YF1Z-6148-BA Piston rings, $30.03 (does 2 pistons)
    - YF1Z-6513-FA Duratec Valve Springs (rated 153 lb/in per manual)
    - YL8Z-6622-BA 01+ Upgraded Oil Pickup (req 01+ main studs)
    - YL8Z-6687-AA 01+ Upgraded Windage Tray (req 01+ main studs)
    - YS2Z-7230-BA 5-R Shifter Fork, Revised (00)
    - YS4Z-7230-AD 3-4 Shifter Fork, Modified Oil Scraper (01+)
    - YS4Z-7K453-FA Shifter Retaining Clip
    Motor mount/Powersteering bracket parts
    (needed for mid '98 and previous years to fit to the 3L block):
    1S7Z3A732AA Bracket, $32.72
    W704693S309 Long Bolts, $5.22 each
    W704694S309 Short Bolts, $3.53 each
    ARP bolts:
    - 253-4701 ARP Head Studs
    - 253-5402 ARP Main stud kit
    K&N Filters:
    K&N Filters
    Tapered Conical - DB x DT x L
    RF-1045 (5.5 x 4 x 8) = 720cfm
    RC-4630 (5.5 x 4.5 x 6.5) = 615cfm
    RE-0950 (6 x 4.625 x 6) = 605cfm
    RE-0920 (6 x 4.625 x 9) = 900cfm
    RU-3530 (5.375 x 4.375 x 7) = 645cfm (3.75" flange)
    Straight Conical - D x L
    RU-1785 (5 x 8.5) = 800cfm
    Miscellaneous parts:
    - Stant Part# 13396 160 Degree T-Stat
    - Bosch# 13246 L1H1 Wideband O2 Sensor
    Tools:
    Rotunda Tool Set - Essential
    T94P-6136-AH Connecting Rod Guides
    T94P-6256-AH Camshaft Seal Protector
    T94P-6256-BH Camshaft Seal Replacer
    T94P-6256-DH Camshaft Damper Replacer
    T94P-6312-AH Water Pump Pulley Remover/Replacer
    T94P-6312-BH Water Inlet Tube Replacer
    T94P-6510-BH Valve Guide Replacer Adapter
    T94P-6510-CH Valve Stem Seal Replacer
    T94P-6256-CH Camshaft Alignment Triming Tool
    T94P-6510-AH Valve Stem Seal Remover
    T94P-6510-DH Valve Guide Replacer Adapter
    T94P-6565-AH Valve Spring Compressor Adapter
    T94P-4451-AH Measuring Fixture
    T94P-4451-BH Differential Shim Selection Tool Adapter
    T94P-7025-BH Multi-Bearing Cup Replacer
    T94P-7025-CH Differential Drive Shaft Seal Replacer
    T94P-7025-DH Selector Shaft Bearing Remover/Replacer
    T94P-7025-EH Pinion Spline Socket
    T94P-7025-FH Gear Lever Aligning Tool
    T94P-7025-GH Differential Bearing Cone Replacer
    T94P-7025-HH Selector Shaft Seal Remover/Replacer
    T94P-2100-AH Sub Frame Alignment Pin Set
    T94P-6000-AH Power Train Alignment Gauge Set
    T94P-70010-AH Transmission Range Sensor Tool
    2005 GTO IBM - 341hp/341tq
    - Volant intake, JBA catless midpipes, H-pipe, GMM ripshifter, BMR skidplate, HIDs, SAP bumper & grilles, CV8-R taillights
    Local CEGers: If you need detailing PM me
    I don't know if these can be used or not, but i found a part number for Clevite main bearings for Duratec 3.0. The part number is MS-2207P. Whats the advantage of these? I'm about to do a engine swap and trying to get the best parts for everything
    Default Complete 3.0 l engine?
    Does anyone know of a company that sells the 3.0l engine as a crate motor?
    98 Silver Frost SVT
    Painted Calipers
    Yokohama Tires
    The Boxer
    May 2008
    SE / CLT,NC / ATL,GA
    999
    all I see here is this:
    is that to say the only source for timing cover gaskets is a ford dealer?
    thanks dudes
    May 2002
    The six-one-six
    2,296
    Is the 3M4E oil pan the same as the 3M4Z?
    The Ignore list : Giving us the ability to surf CEG while keeping our blood pressure's in check, since 2008...
    The correct part number for replacement plugs on the ST220/Mondeo intake are as follows:
    Engineering P/N: W528011S1309
    Ford P/N: F5RZ-6026E
    Thanks to CSVT#49
    98 Black CSVT #1244 3L (Sold - seabass 00SVT)
    88 Festiva LX 5 Speed - Go cart (Sold)
    04 Passat B5.5 1.8T - Grocery Getter
    94 Emerald Green SHO MTX (Rot Free) -Daily Drivr
    May 2004
    Coon Rapids, MN
    2,883
    Quote Originally Posted by pwntbywombat View Post
    Thanks to CSVT#49
    Ah yes you beat me to it. Thanks for putting the info in here... for some reason I was thinking it was locked.
    Also to add to this in the US the part is used as the frost plug on all 2.0L Duratec cylinder heads.
    -Mike
    98 Contour SVT Toreador Red- #49/6535 DOB 3/25/97,178.88whp/157.78ftlbs, Follow my 3L/turbo build here... link
    85 Camaro-1969 350ci, 503BHP
