Results 1 to 6 of 6
Thread: Quick Question On An ATX
    Jan 2005
    California, San Jose, San Diego(School)
    691
    Default Quick Question On An ATX
    Can ATX number F83P-CC drop-in replace F83P-DB? (99 Contour to 98 Contour SE)
    3L process done
    I need a new mod to do...
    All bolt on and transmission mods done.
    TIME FOR TURBO
    Jan 2005
    691
    Those were tranny numbers. I guess I ment to say, will a tranny from a 2.5 contour fit the zetec contour? Thanks
    3L process done
    TIME FOR TURBO
    Sep 2000
    7,332
    I'm sure that they will not for the same reason that the MTX isn't interchangable. The engine bell housing is different.
    Jim Johnson
    98 SVT
    03 Escape Limited
    Jan 2005
    691
    So it doesn't look like it even if they are both ATX's?
    3L process done
    TIME FOR TURBO
    Like he said, bell housing is different between v6 and 4 cyl. It will not work.
    98.5 SVT-187whp-whawhawheel bearing.
    96 ATX Zetec-alive but scarred!
    FS: $100 off $200 or more SPEC purchase
    There are also internal shaft length differences in addition to the different bellhousings.
    Duratec and zetec torque converter are also different.
    1997 Mondeo Ghia 2.0 ATX
