Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: UD Alt Pulley question
    Aug 2005
    Trois-Rivieres, Quebec
    1,106
    Default UD Alt Pulley question
    ok im about to install a UD alt pulley (the one from the nima's gb)
    do i need to get a longer belt ?? since the pulley is a little bit bigger than the original alt pulley, do i have to replace the belt ??
    08 Subaru Impreza WRX 5Dr - WR Blue Mica
    98.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
    RU-3530/CTA Intake, MSDS Headers/Y-Pipe, Magnaflow#10435, SPEC Stage 1/Flywheel, DMD, UD Alt&P/S Pulley, Optimized TB, B&M...
    HERE
    Aug 2002
    Ottawa, Ontario
    1,547
    You probably won't be needing a new belt, i think you should be ok
    3.0 13.5@104 http://www.youtube.com/watch?v=tisIv-JstmE
    NEW 4 bolt control arms $105!
    NEW GCK axles $65 each!
    PM me for details
    Dec 2001
    Enfield, CT
    20,535
    Blog Entries
    93
    well you might be ok, with both pulleys my tensioner was off center, with just the ps pulley since I am having an alternator issue the 73 inch belt puts the tensioner right in the middle ...
    but on a side note, anyone with the alternator pulley experience low voltage at idle with a load?
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    On this subject does anybody know of anybody that bought extra pullies during the GB?As I did not have the cash at the time.Thanxs in advanced
    #985-Born:Jan-25-99
    SVT/SF....with to many mods
    '95 t-red mystique-sold
    Aug 2005
    1,106
    ok i hope it will work with the same belt, and i hope i will not have to much voltage problem.
    i just got mine from somebody who got it from the gb but never installed it, but im still seaching for the P/S pulley
    HERE
    Dec 2001
    Enfield, CT
    20,535
    Blog Entries
    93
    Quote Originally Posted by SVT3Rivieres View Post
    well with no load and a good alternator I say 14.7 volts, now add a very high load, high beams and ac and my volts dropped to about 13 and I got dimming head lights, so I am not sure it is the pulley or the car itself as this is happening with a normally pulley on my alternator with a very high load at idle
    - 95 Mystique LS
    I also have dimming headlights from the asp crank pulley.Its kind of annoying some times and it doesn't really affect my high beams for some reason.
    #985-Born:Jan-25-99
    Aug 2005
    1,106
    but my crank is a DMD im just UD'ing my alt... and p/s if i can find one !
    HERE
  9. #9
    you need a new belt if you are using both pulleys. I don't recall what size it is, but its listed on gb or original gb somewhere.
  10. #10
    Aug 2005
    1,106
    if i use both pulley (DMD and alt) or just if i get a p/s one later ?
    HERE
