Results 1 to 8 of 8
Thread: Weird tach problem...
    Mar 2007
    Sunderland, MA
    5,609
    Blog Entries
    7
    Default Weird tach problem...
    OK, so as some of you may know, I have a V6 tach installed in my Zetec. I did the resistor mod to make the tach read correctly. Today when I started my car, the RPM's were REALLY high, or so the tach said. As it turns out, the tach is reading ~ 3x the actual RPM's. I'm not too good with electrical and whatnot, but could this be caused by a worn out resistor by chance? Or maybe the solder has busted loose? I feel this might be the case, because I installed the resistor to make the tach read HIGHER than it's supposed to in the first place. I'm guessing not enough current is flowing. Now with that being said, does anyone else have any ideas? Or am I on the right track and should I just fix the solder? (I really don't have the time to go through the time to take apart the cluster now, school is killing me...)
    Ian
    Mine - CDW-27 Zetec ATX | Hers - D186 Vulcan ATX
    Aircougar Performance
    Feb 2008
    Vermillion, South Dakota
    1,525
    test the resistor.
    96 Lincoln Continental -- Hey, D186 is a Taurus platform, and people mistake contours for an escort or taurus all the time, therefore, technically, I am not a troll.
    Mar 2007
    Sunderland, MA
    5,609
    Blog Entries
    7
    Quote Originally Posted by FunInNorthDakota View Post
    test the resistor.
    I don't have means of testing the resistor unfortunately. That would require my purchase of a multimeter, correct?
    Ian
    Feb 2008
    1,525
    Quote Originally Posted by zorrex View Post
    yes..
    You can get el cheapo multimeters for like $5 or $10 that will work for basic stuff like that for a little while
    Dec 2001
    Enfield, CT
    21,507
    Blog Entries
    93
    a multimeter is a good tool for anyone to have. but I have one and so does greg. I'll try to bring it to UMass tomorrow if I go.
    but that is alittle confusing. you installed a resitor to make the tach read higher and its now reading even higher? if the resistor broke off or came disconnected I would think it would read lower then before
    - 95 Mystique LS <-sold
    - 99 Contour SE Sport
    - 2k Contour SVT - #2137
    Mar 2007
    Sunderland, MA
    5,609
    Blog Entries
    7
    Well you have to break one of the connections on the circuit board and reroute it through a resistor. So if it broke loose, it would aid in reducing the voltage...I think. I just wasn't sure if there is anything else that could cause this weird situation. I hope it isn't related to my wiper stalk malfunction, like a cracking wiring harness!
    Ian
    Mar 2007
    Sunderland, MA
    5,609
    Blog Entries
    7
    ! Now it's working just fine.
    Ian
    Dec 2001
    Enfield, CT
    21,507
    Blog Entries
    93
    could just be the weather we are having then .... or the wiring harness . although thats under hood only
Similar Threads
  1. starting problem
    By codypka in forum General Troubleshooting
    Last Post: 12-09-2007, 06:07 PM
  2. Battery Problem
    By lunaru in forum General Troubleshooting
    Last Post: 10-23-2007, 06:45 PM
  3. From neutral into 1st or reverse problem
    By erb13 in forum Transaxle
    Last Post: 09-21-2007, 10:23 AM
  4. svt heads and 3l block problem
    By RRT_SVT in forum Duratec 3L
    Last Post: 02-20-2007, 02:34 AM
  5. Power window problem
    By jimmyz49866 in forum General Troubleshooting
    Last Post: 02-04-2007, 10:35 PM
