problem with resetting the pcm right before an OBDII emissions test is you will have a code P1000 which means the PCM was jsut reset and all of the self tests have not been run. You can fail for this.
the mil-eliminators are designed to prevent the P0420 and P0430 pre-cat codes.
one should pass sniff test emissions if the main cat is working and up to temp even without pre-cats. pre-cats are mainly used while the enigne is coming to temp and the main cat is warming up so it can work.
Bookmarks
